I had the problem a few weeks ago and eventually it booted, but I am not exactly sure what I did, or if it was it luck. It worked for a few days and then came back with the problem. I think the recent incident was caused by a bad shut down. I pressed the power button and it shut down without showing the screen to verify shut down. It does that sometimes.
I paid a small amount for this tablet, so if it is done, well I move on. But, if I can get the tablet to restart again great. There must be a way.
