How to restore IMEI if all you have is the number?
    Hello,
    Long story short, I have flashed over the IMEI and I lost the IMEI backup I made with Mobileuncle. Epic fail, I know.
    How do you restore the IMEI when all you know is the actual sequence of digits (I made sure I wrote those down and saved them)?
    Thanks for the help
    Hmm.. a blast from the past.. (where i got the same issue)
    You need root:
    Goodluck
