MXIII-G 1gb ram 8 rom Gigabit >>>S812
    Hello Tuesday I get this tv goodbye
    Como le puedo hacer root y que rom hay disponibles?
    Gracias.
    Product Specification
    System Config. CPU Amlogic S812 Quad Core up to 2.0GHz (Cortex-A9)
    GPU Octa core ARM Mali-450 GPU up to 600MHz
    RAM DDR3 1GB
    ROM Onboard eMMC Flash 8GB
    Bluetooth Not Support
    Expand Memory Micro SD Card (Maximum support 32GB)
    Antenna Built-in antenna for WIFI
    Media UHD 4K×2K Yes Support
    Full HD 1080P Yes Support
    HEVC H.265 Yes Support
    Video/Picture Decoding Supports *.mkv,*.wmv,*.mpg, *.mpeg, *.dat, *.avi, *.mov, *.iso, *.mp4, *.rm and *.jpg file formats
    Audio format Support: MP3, AAC, WMA, RM, FLAC, OGG
    Communication Ethernet 1000M LAN
    WIFI IEEE 802.11b/g/n
    IEEE 802.11b/g/n, WiFi compliant
    2.400 GHz ~ 2.497 GHz (2.4 GHz ISM Band)
    Sensor/Motor IR Sensor 1*IR
    Indicator Power LED 1* power LED with two - color
    Button & Ports Button 1*Power Button
    1*Update Button(via one pin hole)
    USB2.0 2* Standard USB
    1*Micro USB with OTG
    DC-in 1*DC in Jack
    HDMI 1*HDMI A Type
    SPDIF 1*S/SPDIF (2CH, 5.1CH)
    RJ45 1*RJ45
    TF Card Slot 1* Micro SD card slot
    AV 1*AV Port
    Power management Adapter 5V 2A
    Software Config. OS Google Android 4.4
    Multi -language German, English, Spanish, French, Italian, Dutch, Indonesian,Croatian,Catalan, Czech, Danish, Latvian, Lithuanian, Hungarian, Malay, Norwegian, Polish, Portuguese, Roman, Slovenian, Finnish, Swedish, Swahili, Vietnamese, Turkish, Zulu, Greek, Ukrainian, Russian, Serbian, Bulgarian, Hebrew, Arabic, Persian, Thai, Bengali, Korean, Japanese, Simplified Chinese, Traditional Chinese
    Keyboard Qwerty keyboard
    Features Miracast/DLNA Support
    UI Support original ecology and AZW custom UI
    Work Environment 5°C--35°C,30%--90% Humidity
    Storage Environment -20°C--60°C,10%--90% Humidity
    Dimension Item Dimension 115.00*115.00*26.00mm
    Net Weight 203.00g
    Package Dimension 200.00*152.00*55.00mm
    Gross Weight 530.00g
    Enviado desde mi iPhone utilizando Tapatalk
    anyone can tell me how to root and rom are available for this model?
      You could use kingroot and afterwards supersu me, to go to supersu. As firmware you can use the beta lollipop for MXIII-G from Oman. It works fine on mine.
      Verstuurd vanaf mijn MXIII-G met Tapatalk
        thanks that I do when I get the machine?
        Viva España¡¡¡
          Any other part of Oman rom to work properly on the device?
            103L1 have the 5.1.1 version, I do not like how it works, I'm in an application and only comes out, it takes too long to open applications and some get stuck. I recommend any modified or better rom down to KitKat?
            Viva España¡¡¡
