Thank you
beelink i68 system was damaged
Today just opened up my box, a system update was available, download started and after few secs i see a popup message "system was damaged, wireless update is disabled". Just clear cache of system update, rebbot the box and update still cannot be done. Any ideas how to solve this problem?
Thank you
Tags: None
Originally posted by khairop View PostToday just opened up my box, a system update was available, download started and after few secs i see a popup message "system was damaged, wireless update is disabled". Just clear cache of system update, rebbot the box and update still cannot be done. Any ideas how to solve this problem?
Thank you
I have an Andoer i68, a Beelink i68 clone, with installed 205L firmware.
Last week an update was available so I tried to download it but I received the message"siystem damaged blablabla".
Maybe because I before installed supersu app and it changed the install-recovery.sh, as wrote here:
Then I downloaded and copied in the box another install-recovery.sh, taken from here:
www.mediafire.com/view/8lrak3wr6jevfld/install-recovery.sh
but it doesn't work, same system damaged message.
I tried to manually update the firmware to 206L but when I reset the tv box and I connect it to pc, the Factory tool 1.39 doesn't work, it doesn't open the usbport, maybe a drivers problem, I replaced the drivers but same problem.
I don't know what to do now, If someone has the install-recovery.sh for 205L I'd replace it or any suggestion for manual update?
Thankyou.
Originally posted by Farpa View PostI have an Andoer i68, a Beelink i68 clone, with installed 205L firmware.
Thankyou.
Grab the tool that you've linked and the 206L firmware from another link.
Unpacked the tool and install the included driver. This was done under Windows 7. The driver install will give you an error saying incorrectly installed, ignore it.
Start the firmware tool and select the correct firmware, click on "restore" button.
Everything should be disconnected from your i68 box.
Connect the usb to micro-usb cable (USB to computer and micro usb to OTG on i68)
Take a pin or whatever you have press on the reset button and then connect the power cable to the i68 box, the unit should still be in off state.
Do not let go of the reset button, press the power on button and look at your computer screen, it should detect the i68 box.
You can let go of reset button and the firmware should be upgrading, if it isn't then press "RUN" on the app.
Once firmware update is finished you should disconnect everything and then connect it back to your TV and reboot.
You should consider using the Wasser 3.1.3 firmware, it is much better, the internal storage is partition as the full 16gb so chances of running out of room for apps is nil. It does have wireless and bluetooth issues, but if you read the thread you can fix it, just a matter of renaming and adding some files.
Good luck!
Hello
Just my observation
I have since last july had 5 i68s delivered to family and friends mine being the first and ive noticed as i set them up that new apps have appeared Kodi mate and to auto update
i deleted both of these as i find with the press of a button my friends can cause all sorts of problems and as the boxes work perfect on Kodi 16.0 i see no reason to chance fate
Fun,Learning and Mutual Respect ......Its Good to Share
There are currently 1981 users online. 0 members and 1981 guests.
