MXV armlogic s805 TV box switching itself off to standby
Your help will be very much appreciated. I recently purchased the MXV armlogic s805, model chiptrip and the box is switching itself off randomly, most of the time in less than 5 minutes. I changed the display settings from 1080 to 720 and also tried on HDMI and AV port, the behaviour is just the same. Sometimes it just switches off by going on standby (red light) right on boot up and sometime it happens when I am surfing or watchng a video. Have you guys experienced this or have an idea what could be causing this and how to rectify the problem? The seller is abroad and if I return, I will not be reimbursed the shipping, which is quite pricey. ThanksTags: None
Originally posted by yankeebisbis View PostYour help will be very much appreciated. I recently purchased the MXV armlogic s805, model chiptrip and the box is switching itself off randomly, most of the time in less than 5 minutes. I changed the display settings from 1080 to 720 and also tried on HDMI and AV port, the behaviour is just the same. Sometimes it just switches off by going on standby (red light) right on boot up and sometime it happens when I am surfing or watchng a video. Have you guys experienced this or have an idea what could be causing this and how to rectify the problem? The seller is abroad and if I return, I will not be reimbursed the shipping, which is quite pricey. Thanks
I have the same problem with switching off and when I changed the display settings from 720 to 1080 and back the Browser app is deseapeared. Say what way helped with your box and what way to change firmware ( There is 19112015) ?
There are currently 2422 users online. 1 members and 2421 guests.
