Everything has until now been fantastic (5months) with the greatly increased app memory and speed enhancement, even liked the new boot loader image, took a little longer to boot, but it was worth it.
But a couple of days ago something strange happened!!! I had been using my tablet in the evening and switched it off just before bed, then remembered that I had a email to read before work the next day, so I quickly switched the tablet back on again only to find the boot loader riley rom/pipo s1 going round and round interspersed with bright screen flashes. Left it for a while as my charger was plugged in, and nothing changed half hour later I just switched it off.
The day on returning home from work, tried switching it on, only to be met with the sumvision screen nothing else. Ok a bit of head scratching later and connected to my lappy, went through the process of wiping and using the RKBatchTool only in this instance is was appearing as connected blue square only, thought to myself, where has my masked mode gone, is it bricked and why... changed usb ports and finally I got a pink square which I switched and the with the tablet in firmware mode a green at last.
Low level format, and wipe flashed the original English stock rom and my pipo sprang back to life.
Repeated the process and installed the Riley s1 rom and once again I'm stuck with the sumvison screen.
Any Idea's, help would be appreciated regarding this matter.
I am under the assumption that my nand could either be buggered, failing or maybe something else is causing these errors, as everything until now has run flawlessly on my tablet, may have pushed it harder than most.
