did you receive my Inbox Message.Translations nearly ready.But remember i have the UT3 not S,for Future Testing.Tonight i will Test,but first i have to know if i have to change Kernel and something else???
Official Ugoos firmwares for devices based on rk3288
Originally posted by scooter2014 View PostHoly crap missed the new launcher in this release Ola@ I try now lmao
We will include your translations in the next version.
Hi to all and Team
Bugreport
1. FileExplorer first Time says if you open it "Read Error please check File..." if you press again on internal Storage the Directory pops up.The
yellow Frame does not move if you press another Storage.
2. E1550 Dongle works but after Boot/Reboot the 3g don't pop up.The Network search not works correct & always.Reboot helps.K3765 don't
work.Not possible to deactivate the DataPlan no Button found.APN Settings the APN is activated but not blue.(Screenshot).
3.The WIFI still deactivates and disconnects.(XSBoxGO F97)(Video)
4.USB Disk don't shows in Statusbar only in Settings (connected over OTG With USBHub) sometimes
5.Sound on Touch nearly works perfekt if RKMusic plays Music,without only if you press fast enough & same Rate(Default Soundsettings)HDMI Sound
on Touch only work sometimes !
6.Before i uninstalled Kodi i had massiv Higgs & Stutters with MP3 & Video (Stockplayers),after nearly nothing,today MP3 & Video Stutters again with Wifi & BT on.Without much better (same Bugs as early KK Roms)(see uploaded Video)
7. Equalizer BassBoost Bug still exist.
8. Firefly App works perfect,BT Filetransfer works,but there is one Bug in Game Mode on my H2000+ if i press the Button TG or TV the Frame of the Button moves to the left,beside TG.(what does TG mean???) and how can i get back from there???
9. Catlog : no Memtrack Module (same as KK & my M9Pro Rom RK3188 )
10. HDMI IN works,but you have to do it right.
11. Sometimes the over OTG with a USBHub connected USBStick shows up double in RKFileexplorer and Gallery even in Settings/Storage it shows
double a 4 GB Stick shows 8GB.(already happend 4-5 Times)
12. What does the Face Search App???
13. Power LED never works even if it is set to "always on" no blue Light
14. Battery Icon For what??
15. The important Things for me are a working CWM or TWRP Recovery and the possibility to use XPOSED INSTALLER & Gravitybox.I found a flashable Version over Terminal on XDA, i try and report
16 If it was possible to deactivate the Letters under the Icons (only Icons) in Ugoos Launcher would be great !!!
17. Data Usage under Wifi not possible to change the Date cycle.Cellular works.
18. System sometimes has small delays & higgs and make blackscreens if you press back.
19.Lib Files the text inside looks not normal (&}}>-+€$}{]]88¥¥..,€/}]][*/<8>>+<>>8<+<>{[3[*/) something like that with normal parts.
The same i have on my M9Pro (RK3188). I will upload the made Screenshots.
sorry coudn't upload the Videos over Tinypic until now.Try it later again.
for the Team i made some Logs with Wifi & BT on & off while i play Music & Videos with Stockplayers.(RKMusic & GVP)
http://workupload.com/file/hm5Ieog1 Video Wifi Deactivated & MP3 Stutters
http://workupload.com/file/7xbXMx8R Video Wifi Disconnect & Deactivated
i hope it helps.
gefatternLast edited by gefattern; 31 January 2016, 03:25.
Hello gefattern, I am looking for the bugs you list. I have the UT3(2GB/16GB). Some feedback...
1.-Confirmed
2.-I don't use these features/devices
3.-I have experienced no issues with [email protected] setup =Cable modem>Router1>CAT5>Router2-WiFi>UT3
4.-I see USBMassStorage_2 prepared in the notification area when connecting USB disk.(not using hub). I may be misunderstanding.
5.-I don't use this feature.
6.-I have had no issues playing mp3s(USB connected drive and/or iPod), not in Kodi, not in the stock players. - Wifi and Bluetooth on. I do have USB audio routing switched off, don't know if that is a factor. Again, I may be misunderstanding.
7.-Will check later
8.-I think TG stands for Touch Game. I think it is used to address games that respond only to touch. When first entered, it allows you to drag the directional arrows and buttons to correspond with the area of the screen that the control element interacts with on the display. Once set up and saved, it will go to the TG control, selecting one of the other Game or TV will return to those controls. If you do not save the TG configuration, your phone's back key will return you to the other controls. Then select Game or TV, or back again for the Menu. Please see the Fireasy Manual(PDF) for further details. The manual is from the Firefly's Wiki.
9.-Not checked.
10.-Agreed, HDMI IN is a little buggy. When the UT3 is switched off, if a device is connected to HDMI, the UT3 won't light the display when rebooting. Need to test further.
11.-Have not tried a hub, will check later.
12.-I have wondered about this app too. It would appear to be an app that can find faces in pictures, just a guess. It has a lot of permissions, I uninstalled this app on an earlier beta firmware.
13.-The LED on my UT3 works as expected.
14.-Agreed. I reported the superfluous battery icon earlier(beta).
15.-I will be interested in your findings, ref. Xposed.
16.-That would be nice. There is a setting in the options category to "hide tile background". It wont remove the text, but it is more agreeable visually.
17.-Confirmed
18.-I have not observed this behavior.
19.-Have not checked yet.
to add:
If you switch to windowed mode while the Ugoos Launcher is running, it can get a bit buggy. I will try to explain in detail later.
Good day.Last edited by RISCy Dude; 30 January 2016, 11:43.
Hi all
i made some other Videos of the Stutters with Wifi on & off.Will upload it with the logs tonight.So everyone can see it with own eyes.But my UT3 is one of the first 08/14,maybe in newer Boxes something changed.
To Risky i use much of the Functions not,but isn't it important that it works???
Testing goes on
http://i67.tinypic.com/1zojp01.png double UDisk Gallery
http://i66.tinypic.com/2hcjj7r.png dualscreen Bug
http://workupload.com/file/vTGkJxZl after Reboot
http://workupload.com/file/o95Jjs5W Audio Stutters Wifi on off
http://workupload.com/file/yCnTPCpy Video Stutters Wifi on off
Once more Team & AvA
here are the saved logs with catlog i was offline til i did them.
Tonight i will upload another Video with connected BT Speakers,same behavior.!!!!!!!
I forgot that it is not possible to change the visibility of BT,like on other Android Versions,and i would be great that CPU Temp/Freq/Ram shown without the Letters only Number looks nicer / like : 40°C / 408 MHz / 1,97 GB
Found one more Bug under Keyboard Setting / Android Keyb. / other Options / it is not possible to deactivate the Next Word Suggestions.
I tried to use Sixaxis but it did not work,App says always : Error only position independent executables(Pie)are connected!!!!! What does this
mean??? Internet says something wrong with some "Api Settings"
Is someone already using Sixaxis with PS3 Controller with LP.Without Sixaxis i cant play my Games,so i decided to flash back to 2.2.0.
Please AvA if there will no 2.2.1 what about a Stagefright Patch for KK Users.That is really important for all Users with 4.4.2.
LP has the same Kernel Version as KK why no typical LP Kernel 3.4. ...???
Before i go back to KK i tried Mo's 1.3 same Stutter behavior with Wifi on/without nothing ( Audio & Video ) otherwise nice Rom.
Maybe my Sixaxis App Version 0.7.0 was not LP compatible,give 0.7.4 a try and report.
E1550 directly connected it makes no Problem same as 3.0.4 but not over USB Hub no 3g
It looks like every Dev or Team using the same Stockrom for building.
To AvA shall my Rev Nr & Builddate help to see if my box maybe has some other parts,builddate is 2014-8-7.
Will it be possible to take a System.img from a Pipo P Series Rom for our Devices???
Will send both again with Inbox,OK.???
Hi Team & all Users
First i want to know if the Freaktab Page wasen't reachable the last 2 Days Freaktab was down???
Bugs
1 / Ugoos Launcher if you long press an App the Changemenu is not German.
2 / Clock Bug 24h Mode only shown in Launcher3 not in WindowMode.
3 / In WindowMode i was not possible to restore Games with TBackup Device says not enough Space.
4 / Ugoos Launcher 5 rows Bug cuts off a part of Icon.
5 / still Tranlation Bugs in Ugoos Launcher :
Category "Rahmen" a Rahmen is a Frame of wood or other Material where a Picture comes in or on (Painting),
so better delete this Category and put this 3 Apps inside Tools in German "Werkzeuge" much better.Same for
the Category "Andere" better delete this and put it under All.
Under Options hide tile back.... better " deaktiviert den Kachelhintergrund" & "benutze Systemhintergrund".
Still Problems with Networksearch and 3g Dongle sometimes it works sometimes not.Sixaxis and Ps3 Controller works but newest
Pair & Sixaxis App are needed.
It would be nice if it is possible to deactivate the Letters in WindowMode from Startmenu and Screen,even in Launcher3 it is not
possible to deactivate the Letters.
I am really want to know how many UT3 are sold over the World,and why we are only a few people here.If i were Ugoos i
directly advice this Site to my Byers.
The only thing i have to test is xposed installer !!!!???? and i will upload Pic & Vid.
http://img5.fotos-hochladen.net/uplo...g76rct3vux.jpg
look at TB App in left Corner happend after i changed from WMode to ULauncher and i thing when you use in UL Systembackground.
http://img5.fotos-hochladen.net/uplo...rn1df3x467.jpg 5 rows Bug in ULauncher
http://img5.fotos-hochladen.net/uplo...8n3vpjul57.jpg Screenproblems after Reboot
http://img5.fotos-hochladen.net/uplo...befci3arq8.jpg after Reboot
http://workupload.com/file/C6fR6OVs WMode to ULauncher same as Pictures above
http://workupload.com/file/Es75yDC8 BT Audio Stutters Wifi on off
I hope that was all because now i can go back to 2.2.0 Stagefright Rom.I hope that the Dev's will bring a Patch for it.
Hint for Risky Xposed Installer installing over Terminal ( XDA Xposed Installer Reborn ) does not work,we need a working
Recovery.I flashed a CWM Recovery for LP from crewrktablets.com.It works with BT Mouse only the Screen is a little to
wide.
Have a nice Day
gefatternLast edited by gefattern; 05 February 2016, 03:28.
The biggest Bug for me is that I have audio dropouts every about 10sec if I hear DTS-HD sound over HDMI. I use 23,976fps. With 59,xxx fps I dont have audio dropouts, but video is not so smooth.
Whit Wasser FW 3.0.4 and this Kodi extracted from this FW the sound is working without dropouts.
Icons in Kodi are not correct if I use 3D mode
There are currently 2301 users online. 0 members and 2301 guests.
