M8 bricked (hard?) trying everything, dont work...help
So, i have bricked and unbricked about 6 m8's(shorted pins, usb burner, sdcardmaker, etc), but with this last one (hope not really last, hehei have experienced a really ''mountain''. So, after i get it i put on openelec 5.9.5.3.2 from amlinux.ru and from then i cannot put the m8 back on ''right track''. When i plug in (blue light works), but on screen - black, if i put back on sd card 5.9.5.3.2 openelec it installs, then put me over and over again in recovery menu. I tried via amlogic tools to burn proboximage (like 2,3 times before on other m8's - it works), it doesnt connect. Even when i connect usb (m8) to pc the blue led doesnt turn on (on other m8's i didnt need to plug in electricity and than usb to get work). So, what to do? thanks
Tags: None
Try to use my procedure for amilogic from sdcard ( dont short any pins ). You Need firmware img format , and u-boot.bin for you device ( from zip update fie. or try to use u-boot.bin from megatron firmware - find in google)
If failed try again witch short pins on YOUR NAND - search in goggle what pins must be short.
If you need i have file ini.
Read this :
I need firmware ROM M8S
Read More at : freaktab.com http://freaktab.com/forum/tv-player-...m-m8s-and-help
@hipisxbit-No, i'm from Slovenia, anyway,...short pins, etc didnt work out (like i mention before), so connection via pc usb dont work...BUT, i manage to put it back to life with bootcard maker: i made u-boot.bin from bootloader image from firmware, i renamed probox2 firmware to aml_upgrade_package.img, and add file aml_sdc_burn.ini and it put it on SD CARD. One thing to mention, it was M8N!! not the M8 like seller advertised and later confirmed.Anyway... now i have my boxy back into work statusNext step, where to find openelec for M8N? thanks.
There are currently 1438 users online. 2 members and 1436 guests.
