Amlogic M8S vs MXIII-G difference ? >>>s812
    Hello,
    what difference is there between M8S Box and MXIII-G box ?
    both have the same feature : processor (Amlogic S812), same ram 2g ect.... what is the difference ?? because I found OpenELEC (JARVIS) for M8S and let me know if it is possible to install it on my MXIII-G
    link : http://amlinux.ru/image/devel/
    I have in my home 2 intel nuc with openelec JARVIS and I also would need this version on my android box (i have try Jarvis for android but is not steady as Isengard....) In openelec Jarvis (alpha) is better than isengard and more steady (alpha is more steady that final release isengard )
    Thank you in advance for your response.
    Originally posted by Deki View Post
    Hello,
    Hello
    This version flashes but it's not booting up. Use the one from here http://www76.zippyshare.com/v/w2Y1M9WQ/file.html
    It work very good (its from a tronsmart device). It wont power off from openelec menu (you have to turn it off manually)
    see this posts http://freaktab.com/forum/tv-player-...g-amlogic-s812
      Thank you for your reply markthepig yes i have try this release but is very annoying not being able to trun off directly in Kodi. I will follow with great interest the evolution and your post
