You must be wondering what makes this model so special. Well, it offers amazing features for the price of only $85 5.0 display, 64-bit Quad-Core processor, 2GB RAM, 16GB of internal memory, 2 cameras, 2400mAh battery and Android 5.1 Lollipop! You are interested, arent you? Its OK, so am I.
A well-recognized web site specialized in selling mobile phones, tablet computers and accessories, Pandawill, has provided a copy of the Doogee X5 Pro for testing and writing this review.
Technical specifications:
- Processor: 1.0GHz Quad-Core Cortex-A53 (Mediatek MT6735, 64-bit)
- Graphics chip: Mali-T720
- Display: 5.0 IPS LCD 1280x720 pixels (sensitive in 2 points simultaneously)
- RAM: 2GB
- Memory: 16GB ROM (~12GB user available) + microSD slot
- Back Camera: 5.0Mpix (interpolated 8.0Mpix), autofocus, LED flash, video 720p@30fps
- Front Camera: 2.0Mpix (interpolated 5.0Mpix)
- Battery: 2400mAh (removable)
- Connectivity: WiFi 802.11b/g/b, Bluetooth 4.0, microUSB, OTG, GPS with A-GPS
- OS: Android 5.1 (Lollipop)
- Dimensions: 145 x 82 x 40mm
- Network: 2G 850/900/1800/1900MHz, 3G WCDMA 850/1900/2100MHz, 4G FDD-LTE Bands 1/3/7/8/20
- Other: Dual SIM, FM Radio
Package content
Doogee X5 along with its accessories comes in a compact box, the design of which is simple, but quite interesting. On the top there is a light-reflecting X5 Pro mark, while on the bottom you can see phones most important features. On one of the sides of the box, there is a scratch sticker hiding the product authenticity verification code.
Upon opening the box on the side, you can pull out the content of the box phone, charger, USB cable and short manual. A protective foil is already on the phone, so its new owner doesnt have to go through the trouble of applying it himself.
The charger is standard, with a generic shape and specifications of 5V 700mA. However, it would surely be better if the manufacturer had provided a charger of at least 1A to shorten the charging period.
The USB cable given with the phone could be used for phone-PC data transfer as well as for charging it is not limited only to the charging capacity.
The short manual covers the basics of Android OS use, and thus will be useful only to the beginners in the Android world.
The 2400mAh battery is already inside the phone when the buyer gets it, but before he starts using it, he needs to remove the protective foil off of it, as is specified on the box.
The absence of stereo headphones from the package implies that the manufacturer wanted to lower the price as much as possible, which will not bother most of new users, since they will already have headphones of their liking.
Appearance
Doogee X5 Pro has a simple design and the model we received for the purpose of this test is completely black (there is also a black-and-white combination). It is considered to be a phone of average thickness (8.2mm), but you can feel it in the hand because of its weight of as much as 130 grams. The battery cover takes most of the phones frame, thus in a way protecting it in case of falling on one of its edges.
On the top side of the phone there are connecting ports a micro USB port (for charging, as well as PC and peripheral devices connection) and a 3.5mm audio connector for headphones.
On the right side there are buttons for sound control and turning the screen on and off. They are very sturdy, well responsive and have a distinguishable click, which makes us think they will endure usage for long period of time.
Microphone and speaker openings are on the bottom side of the phone. As far as sound is concerned, it is very loud and reproduced in satisfactory quality, so the phone can be clearly heard even if it is carried in its own case.
The biggest part of the front side is occupied by a 5.0 display. Even though there was available space for the control buttons to be on the screen itself, the manufacturer decided to place the capacitive buttons (Menu, Home and Back) below the screen. This is a better option for some users, since the entire screen is available at all times, while others will be asking why the buttons arent on the screen, since it will additionally make the phone smaller. Unfortunately, capacitive buttons arent backlit, which makes them hard to see and use in the dark.
Above the screen you can see the front 2Mpix camera, proximity and light sensors, as well as the speaker opening. In-call sound quality is clear and loud, even in the middle of the sound control bar.
The battery cover is smooth to the touch, but covered in rubber-like plastic in order to prevent slipping and allowing better handling of the phone. Perfectionists will be bothered by the fact that the phone will constantly be covered in finger prints, and so they will have to wipe it with a cloth regularly.
In the upper section of the phone there is a 5Mpix camera, not far from the flash LED. In addition, under that exact spot the Doogee logo is discretely, but clearly visible.
The battery cover is firmly attached to the front of the phone, so we advise careful removal so as not to damage the cover holders, although it is our opinion that they are flexible enough not to break quite so easily.
Upon cover removal you can see the blue 2400mAh battery, above which there are 2 SIM slots (both Micro-SIM sized), as well as the slot for a microSD memory card capacity up to 32GB. In order to access these slots, it is necessary to remove the battery from its setting.
The SIM slots are numbered 1 and 2, but that in no way determines which of the cards will be the primary one, since the user himself can choose which card to use for calling, messaging, surfing the mobile Internet (4G!), etc.
The phones surface looks impressive even though this is a budget phone. Yes, there are small traces of plastic injection near microUSB port opening and 3.5mm audio port, but it is barely noticeable and in no way diminishes the beauty of the phone. It is a pity that X5 Pro is missing the notification LED, since it would eliminate the need to turn the screen on in order to check for any missing calls or text messages.
Display
Doogee X5 Pro comes with IPS 5.0 display with 720p resolution (1280x720 pixels). This makes it a very good choice for a screen of this diagonal, because the pixel density is high enough so that the image is as clear as it can be expected although there are phones with much higher resolution on todays market. We have secretly feared that colors would seem washed out while the visibility angles would be narrow, but that is not the case at all in X5 Pro. Color intensity is fairly good, whilst image rendition stays the same until viewing in extremely sharp angles. The manufacturer states that the phone comes with Gorilla Glass display protection, but it remains untested in that aspect.
Screen reacts to the touch very well and its responsive in 2 points at the same time, thats enough for most uses, including playing games. The only problem we noticed its that it reacts a bit unprecise when fingers are too close to each other, that make a pinch-to-zoom gesture a bit difficult.
Back lighting can be very intense, which makes the displayed content visible even in direct sun.
Software
What is interesting is that Doogee X5 Pro comes with Android 5.1 (Lollipop) OS, which means the phone is adorned with both good hardware and optimized software. Software appearance and its functions do not differ excessively from Google source code, although there are certain additional phone setting functions offering further possibilities.
Android 5.1 has finally brought dual SIM native support, so manufacturers have no need to create their own solution to the problem of selecting SIM cards in lieu with each situation. When a SIM-using app is run (Dialer, Messaging, Hangouts, etc.), notification menu displays the possibility to choose which SIM card will be used at that point. It is also possible to predetermine the use for each card, further simplifying the entire process.
It is possible to turn on certain gestures to facilitate phone use, such as flipping the phone onto the screen in order to silence ringing, answering a call by lifting the phone a bit more quickly, or simply switching to speakerphone and back by bringing the phone closer to the ear.
What is more, the phone has the option of turning on with a double display touch (Double-tap to Wake), sliding down on the screen while turned off in order to quickly run the camera, or writing on the screen to run apps like dialer, Internet browser, Play store, messenger, etc.
The Visitor mode solves the problem many have been dealing with since the appearance of mobile phones denying access to certain parts of the phone. By activating this particular mode, you can hide call lists, SMS messages, pictures and disable modification of main screens on the phone. This is an excellent option to activate before lending your phone to a friend. However, in order to turn this option on and off, you need to enter your PIN.
Similar effect can be achieved by means of AppLock app, which does exactly what its name indicates locks apps, but you must enter your PIN first.
Moreover, the proximity sensor also has certain phone management functions. By waving your hand above the sensor, you can scroll pictures, shuffle songs, take photos, change pages in launcher, unlock the phone and answer a call. As to how smart of an idea this is, we will let you decide.
More advanced users will like the built-in option of controlling app permissions (Permission Manager), which means that any app can be simply revoked the permission to dial, send messages, read location, access contacts, use camera, etc.
All in all, Doogee X5 Pro has left a favorable impression as far as OS and additional apps are concerned. Thanks to Android 5.1 OS, animations are beautiful and fluid, transition between apps is fast (for which large RAM memory can be credited) and there wasnt even an instance of unexplainable stalling. With basic preinstalled apps installed, only 500MB RAM is occupied, thus leaving a lot of space for installing and multitasking between large numbers of apps.
Camera
As previously stated, Doogee X5 Pro on its back has a 5Mpix camera (interpolated to 8Mpix) with very limited possibilities, while on the front it carries a 2.0Mpix camera for video chats.
The 5Mpix camera has autofocus, LED flash and makes 2560x1920 pixel pictures without interpolation.
Camera sensor possibilities are quite poor. While colors are good in the daylight, it lacks detail even with taking photos with a steady hand. Photos seem good on the screen, but when zoomed to their previous size, there is a visible lack of sharpness and oil-on-canvass effect. Photos of closer objects are satisfactory in sharpness, but most landscapes make you want to give up the sport. This is quite a shame, since the camera software has interesting options such as automatic photographing by lifting 2 fingers in the shot, automatized following of an object and taking its picture, recording live (making a 5-second long video with a photographing effect) and the Face beauty mode, which removes skin imperfections and makes you more pretty (the fare sex loves this option in Samsung phones).
Photo samples:
Battery Life
Doogee X5 Pro comes with a 2400mAh battery, which is enough capacity to allow the phone one-day autonomy with more intensive use. Seeing how the processor is economical and works on lower frequency, battery consumption is moderate. We have measured its autonomy by inserting 2 SIM cards into the phone (one in the 3G/4G mode and the other in the 2G mode) and running synthetic tests, making a few shorter phone calls (about 20 minutes in total), taking pictures outside for about an hour and a half (during which time mobile Internet was active), testing its speed of access to the 4G network, and then surfing the Internet using WiFi connection.
During all that, the screen was on for 4 hours and 30 minutes, while the phone was off the charger for 30 hours! We believe this to be an excellent score considering all this phones features.
Performance
Doogee X5 Pro is based on MediaTek MT6735 64-bit chipset which is increasingly present in lower-middle class models. MT6735 has a Quad-Core processor at 1GHz (988MHz, to be more precise), Mali-T720 graphic chip and 2GB of built-in RAM memory.
The processor is probably intentionally limited to lower frequency instead its maximum (1.3GHz) in order to enable better battery autonomy, since it has proven to be quite economical and still powerful enough for most users needs. Judging by synthetic tests, MT6735 chipset at 1GHz frequency performs in the rank of Snapdragon 400 chipset and its Quad-Core processor, which is an excellent trait considering the price of X5 Pro phone.
It also has built-in USB OTG option, so it is possible to connect USB flash drive or USB mouse or keyboard directly to the phone using USB OTG adapter.
Obtaining GPS locating on this phone is quick and precise, since it easily finds a large number of satellites and connects to most of them in 30 seconds. Therefore, it can definitely be used as GPS navigation with matching navigation software.
Benchmark tests results:
Conclusion
Doogee X5 Pro is a smart phone which has suddenly appeared on the market and attracted a lot of attention with its surreal hardware for a good price. Its IPS display with wide visibility angles and quality rendition will allow undisturbed use in all conditions, while its work speed will satisfy all less and moderately demanding users. If you want an affordable smartphone and you can look past a few smaller cons, there is no reason to be apprehensive you should definitely take the X5 Pro model into consideration as best buy in the lower price range!
Pros:
- Quality display
- Fast response
- 4G LTE support
- Powerful speaker
- No notification LED
- Capacitive buttons unlit
- No gyroscope and g-sensor
Author: Stevan Stevanović
