Thank you for info to the Slovakia
Cube U65GT 1423 Android 5.1.1
the answer is simple: NEVER. but everything works fine, so, who cares?
You can't install rom from Samsung tablet on U65GTif you appreciate my efforts this is the link for any donation:
Hello, android marshmallow i got to work for 5 minutes on the cube u65gt. At least the build number says it's 6.0 version of android. To get there isn't really difficult. Just get MysticOS from the net for for example mlais m9 phone. Then adjust the rom(port it) using android kitchen or mtk firmware adapter tool. Funny thing is once the zip file is copying through cwm, and you reconnect the tab to your pc and flash the atlantis boot.img, the rom just runs. It's after about 5 minutes of usage, the screen will fade out, no button it will respond to. They keyboard issue isn't solved with installing the new version and you can use it for only 5 minutes. That may sound like a sytem app is started up after that time, making the screen go grey and not respond. Maybe some app isn't compatible with the new rom.
There are currently 2602 users online. 0 members and 2602 guests.
