They have been extracted from ZIDOO_X6 Pro_v1.0.16_ota and ZIDOO_X6 Pro_v1.0.18_ota
Zidoo Kodi 15.1
Zidoo Kodi 15.1
Here are the Zidoo Kodi 15.1 APKs. They only work on RK3368
They have been extracted from ZIDOO_X6 Pro_v1.0.16_ota and ZIDOO_X6 Pro_v1.0.18_otaLast edited by amclean123; 30 October 2015, 18:21.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX PlayerTags: None
Originally posted by clarkss12 View PostFrom everything I have read, it is missing the PVR addons. Can you confirm? ThanksTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Zidoo, the awesome company they are, just release the custom release (based on Kodi 16) called ZDMC. It is available from Zidoo here: http://forum.zidoo.tv/index.php?thre...133/#post-7217
kind regards
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
kind regards
http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
Hi
I also released NTMC(Nagrace Times Media Centre) 16 final, it should work on any RK3368 tv box with the latest firmware supporting Mediacodec pass-through.
Not sure how it compares to ZDMC, I will give ZDMC a try too.
Mo, did you get a chance to compare NTMC and ZDMC?Tronsmart Orion R68 Meta
CS968 -> HTC_T018 v4 20131216 with MTK
GM282 (aka CX 919 II aka J22) - dead
Both ZDMC and NTMC did not install, maybe because Kodi is already installed. VidOn still installed and works. So I should be able to edit apk to look like a different app? If yes, then what attributes to edit?Tronsmart Orion R68 Meta
Originally posted by Vinc3nzo View PostHi!
i'm share ZDMC v16.02 from firmware ZDMC x6 1.0.34 (Rockchip 3368)Tronsmart Orion R68 Meta
Originally posted by Ben.Efrati View PostWill work on Ugoos 3.0.4 (for rk3288)?
Originally posted by ghanashyaml View Post
Thanks a bunch! I will try it out soon. Question still remains though that, can the apk be modified to show Android that it is a different app?TRONSMART R68: Firmware "HPH NT-V8 ROM V1.2 (Dual-Boot) by mo123" (DTS-HDMA, Work)
ONKYO: TX-NR 809
There are currently 3162 users online. 1 members and 3161 guests.
