FREAK TAB HEADER
I kind of like it!
It's been awhile since I changed those... let me see if I can remember how to do it.
On the topic of FreakTab Headers I can't see the FreakTab header with Adblock Plus enabled. I know I can disable it for the site but since it's just a banner header I don't believe it should be blocked unless there's something peculiar happening in the way it is being called.
You may want to find out if this is a known problem with the forum script you are using and see if there is a workaround or maybe an update to the BB code.
We are using the Ad banner software to display the top header. This is the only way to allow it to rotate different header images.
Originally posted by Finless View PostWe are using the Ad banner software to display the top header. This is the only way to allow it to rotate different header images.
I know that a lot of sites I go to have a rotating header image that display's the image properly with Adblock Plus. It's usually all about how the image call is made. If you are hosting the images on a site other than on the server , that would be a big reason. I would recommend hosting your header on the server box and make sure the image call is made to a local address rather than making an external link type that is actually grabbing the file locally.
Basically it should look more like:
<img src="sunset.gif" />
vs
<img src="http://example.com/sunset.gif" />
For a clearer description read here
Realistically it should be a rather quick simple fix. It could also always be because it sees Java making a call for an external file. I'm assuming it's a Java call, because when doing fun stuff like rotating images, it usually is.
Yes we are using a third party add on that we call to display the image. I put a iframe tag in the vbulletin code which uses this ad program.
Originally posted by atomwood View PostGot bored, made a freak tab header.
Thanks,
atomwood, you have noticed your art is now sported on this site?
There are currently 1730 users online. 0 members and 1730 guests.
