My kernell is 3.0.8+ rk3066 cpu Mk809II
Gameloft fix fail for me could someone send me a patched framework.jar for rk3066 3.0.8+ kernell
I tried to patch my framework.jar file myself by following the tutorial from Christian Troy gameloft fix but it does not work for me. Is there someone with a finless rom with the gameloft fix that could send me that file please.With a root explorer you will find the file in system/framework/framework.jar
My kernell is 3.0.8+ rk3066 cpu Mk809IITags: None
Why are you not just running one of my ROM's with the fix? Or take the framework from one of my ROMs?
No offense but this is kind of a crazy ask without telling us what your trying to do?
Oh and most the posts on the Christian Troy gameloft fix are so out dated they wont work anyway on the latest stuff! YOU HAVE TO KNOW THE SMALI CODE and WHAT IT IS DOING to patch 4.1.1 and especially 4.2.2 on TV ROMs.... they are NOT tablets!
Originally posted by Finless View PostWhy are you not just running one of my ROM's with the fix? Or take the framework from one of my ROMs?
A suggestion would be to use the kernel.img from the stable ROM you found and use one of my ROMs for the rest. Stability issues are usually that the kernel is not for your hardware. Using the kernel for your hardware will make most other ROMs work (usually).
Give it a try. If that doesnt work, maybe I look into making a ROM for your specific model.
What is it anyway? You say MK809ii but it appears you think it is something else?
It is a mk809II but there is something strange there are many that reports that your finless 1.7a and 1.7b for imito mx1 runs well on mk809II and the one for the measy uc2 is supposed to work well too but for me my mk809II is unstable wifi and bluethoot work but after a while the android stick will crash or freeze or even reboot. I though it was a defective device first but after i found a rom from this forum http://www.armtvtech.com/armtvtechfo...php?f=4&t=1769
Now my MK809II is faster very stable and responsive and never had any bug or strange behaviors with some apps it is almost perfect except the gameloft fix. Sure if i had the kernell.img with your tool i would prefer fineless rom because there are features on your rom that i want. I don't know how to extract the kernell from the .img of that rom if you could help me to get the kernell i will try your rom with it and give you my feedback
Thank you for your support i know your time is precious and with the new rk3188 devices you must be very occupied
I am at work right now but I will see if one of the other Dev's can pull kernel.img for you.
If not I will do it later tonight. Hang tight it's a short job. I just cant do it at work.
One of the guys says the download link is no good anymore.
Can you upload that ROM to google drive please?
Originally posted by JDfense View PostI have the MK809IIR2.img unpacked, but the kernel seems to be in the boot.img.
Lets see, if I could get the kernel.
JDfense
If i take the finless rom 1.7a for imito that is wifi and bluethoot compatible all that i need to do is to replace the kernell image with the one you will unpack in Bob' s tools?
There are currently 1910 users online. 3 members and 1907 guests.
