X2 TV BOX KODI optimizing4K 30fps / 4K H.265/ 1080P 60fps Video test
OTA: After the upgrade is complete , Into the system desktop interface ,KODI for data backup reduction the operation ,5 minutes, please do not startup KODI ,In order to avoid loss of user data.
Not sure what you mean with "OTA: After the upgrade is complete , Into the system desktop interface ,KODI for data backup reduction the operation ,5 minutes, please do not startup KODI ,In order to avoid loss of user data."
What do we need to do?
after installing firmware - turn box on -
when it boots to launcher
wait another 5-10 minutes as Kodi + other apps will self install
as specified do not start or use Kodi during this time
Thanks for the info. Just installed it then applied the OTA update. Will wait and see what happens next. I noted that Kodi wasn't installed (kodi updater was)
Well as I said I installed it, left it plugged in (switched ON) for an hour, NO KODI. SO I DOWNLOADED IT. Where did you find it It isn't in the apps menu.
I do not know why you had such an issue, I just reflashed my box with the above.
after a few minutes it asked me to auto-update, it downloaded and installed the latest firmware automatically
in both instances Kodi was available
I don't know either, but I have documented what I did each time. The 2nd flash with format just sat on the boot screen for 10 minutes before I gave up on it.
