Genuine MK808B HDMI Cable/Power Supply/Power Cables That Work For You
    Hello all,
    Since buying the MK808B in December from geekbuying, I have not been able to get a audio/video signal without the use of a A/V receiver and or utilizing a Logitech revue. Not sure what the problem is, yes I have tried other 5V/2A power supplies and Monster HDMI cables to no avail. Could some of you reply with your working setup that have a working set up post specific combination of HDMI, usb, and power supplies that are working properly for you. All your help is appreciated. If you could also post the links to the place where you supplied them would be a big help if it is allowed by the forum. If they can be bought from amazon that would be a bonus for me. I just bought a panasonic 42" versa S60 and still get no signal. Frustrating is an understatement.
    Just looking for a power supply, usb cable, hdmi cable that works for you and where you got it.
    Thanks In Advance,
    Bigdaddy
    Nexus 7 power supply works like a champ, I'm otherwise using stock stuff. Don't trust the no-name Shenzhen PS plugs at all. Most of them are labeled much higher than they are.
      PS vita PSU is working very well too in my mk808b, His specification announce 1,5A, but works flawlessly with my device.
      My devices:
      Gearbest.com)
        Thanks for the quick replies. Leolas, what hdmi cable are you using?
          AW: Genuine MK808B HDMI Cable/Power Supply/Power Cables That Work For You
          On wich HDMI port you plug in your Stick Cable?
          Try it on Port 2 or 3. On my Samsung I have to use Port 2.
          May there is a new Firmware for your TV.
          Neomode Freaktab.com Developer
            Okay, so I tried an apple ipad charger that is 10w and 2.1amp, still no signal to tv. I tried both the hdmi cable that came with the mk808b and a monster brand hdmi cable. I also made sure the firmware on the tv was up to date, and it was. But if I plug the mk808 into the A/v receiver or Logitech revue it works fine. Thanks again for all your suggestions, you guys keep me from smashing the darn thing with a hammer.
              Ok so I think it has something to do with the stick not dectecting that is plugged into the tv. I plugged it into the logitech revue and viola, we have tv. I am using finless bob 1.6, not that it matters. What the heck is the logitech revue doing to make it work. Is it extra power, or is it manipulating the signal type so it is useful.
