SHARE CONTENT FROM ANDROID DEVICE TO MK808B
    Greetings.
    I want to share some folders (e.g video, audio, pics) from my Galaxy S3 mobile phone to my MK808B. I used many apps (like this one https://play.google.com/store/apps/d...S5jbWMuZG1zIl0.) but i was unable to find my GS3 device (through mxplayer-lan and ehomemedia). Any ideas that should work?
    Originally posted by Haris1977 View Post
    Greetings.
    I think you are doing this the wrong way round. You need to install a uPnP/DLNA renderer on the MK808B, the GS3 then acts as the media server to send it's local media to the renderer (the MK808B)
      Greetings.
      I think you should try "imediashare" app. Just install this app into your phone and use with "ehomemediacenter" app that reside in your MK808B. Both devices must stay in same network router. It should work well. Anymore question please ask...enjoy!
        https://play.google.com/store/apps/d...id=com.cmc.dmr
        I have found the solution.
        I installed this little app on my Galaxy S-3 mobile phone https://play.google.com/store/apps/d...S5jbWMuZG1zIl0. in order to make it a server. Then i installed this https://play.google.com/store/apps/d...S5jbWMuZG1jIl0. on my MK808B machine and now it works
        Thank you!
        P.s : I also tried ehomediacenter to "see" my phone but most of the times it could'nt find it. And when it did, it always crashed when pushing the back button. I guess the specific app sucks.. Anyone has the same problem??
