Bricked OTT TV BOX M8S
I have a m8s that I tried updating and have managed to brick attached are the shots of the board and the results of the attempted update.
I just want to use this as a media player as it will live in my car but stupidly tried to update it and broke it a few days before we are due to go away.
Please helpYou may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Originally posted by Hman205 View PostI have a m8s that I tried updating and have managed to brick attached are the shots of the board and the results of the attempted update.
Please help
Originally posted by redliquid View Post
If the error persists if you trying to reflash it again? Have you tried to download this firmware again or just another power supply?
The M8s is connected via USB to My Surface Pro4 Win 10 via USB and has its PSU connected.
it gets to 96% of Downloading system quite quickly then Errors with the same error as beforeLast edited by Hman205; 06 August 2018, 08:53.
I have redownloaded the flash and tried again same result.
Originally posted by Hman205 View Post2 mins I did actually get it to complete by pulsing the refresh button on the USB Burning tool when it got to 95% and it eventually completed but the box still doesn't appear to do anything
Ok so still no blue light apart from a tiny flash as I put the power in
it doesn’t display anything on the tv screen but my pc still sees it with the usb burn tool.
I applied the cyx_m8s_v8.6_ap6330_8g2g_kodi_addons_ota_150908_US B.img
Firmware and when it got to 96% I kept pressing refresh until it sauid the image completed successfully
Originally posted by Hman205 View PostOk so still no blue light apart from a tiny flash as I put the power in
This firmware should work with wifi and bluetooth:
https://mega.nz/#!ZJJ0kLjC!Ur-8oOmga...gK5UfmCaGa68pQ
If not, try this - SD Card method should start, when device is booting properly:
https://mega.nz/#!9d5ywa6S!mW7scmK3N...HDYv7e_y5_a300
I have a board with version M8 V8_9 20151031 that was rebooting after the logo. Booting to recovery wasn't fully working (after a start with the reset pin pressed it would show a yellow 'rebooting' text left below of the screen and then indeed reboot) Upgrading with the entertainmentbox firmware didn't solve the issue (only changed the logo).
I used the firmware of the first link and put in on a SD card with the program Burn Card Maker program. Then booted with the pin pressed and it started upgrading successfully.
The box now works with WiFi.
Though I'm not sure what to do next with the box. Maybe upgrade to a higher Android version (any suggestions for a firmware?)
my board:
There are currently 3391 users online. 0 members and 3391 guests.
