K1 DVB-T2 KODI TV BOX Android 4.4.2 Amlogic S805 Quad Core 1G/8G WIFI LAN HDMI 1080P DLNA AirPlay Miracast 3D
    This looks like a bit of fun S805 and Tuner
    Model: K1 DVB-T2
    System
    Operating System Android 4.4.2 (KitKat)
    Amlogic S805 Quad core Cortex A5
    Quad-core Mali-450MP GPU @ 600MHz
    3D graphics acceleration
    RAM DDRIII 1GB
    ROM Flash Nand 8GB
    Extended Storage TF CARD Support 1~32GB
    Connectivity
    Wifi 2.4G WiFi
    Ethernet 10/100
    Bluetooth N/A
    Video Supported
    HD MPEG1/2/4,H.265/HEVC , HD AVC/VC-1,RM/RMVB,Xvid/DivX3/4/5/6 ,RealVideo8/9/10
    AVI/RM/RMVB/TS/VOB/MKV/MOV/ISO/WMV/ASF/FLV/DAT/MPG/MPEG
    Audio Supported MP3/WMA/AAC/WAV/OGG/AC3/DDP/TrueHD/DTS/DTS/HD/FLAC/APE
    Picture Supported HD JPEG/BMP/GIF/PNG/TIFF
    Resolution 1080P
    Language Chinese , English ,Germany ,Japanese, Korea etc. 24 languages
    Ports
    HDMI Port Standard HDMI Male 1.4b
    Other Interfaces 4*USB HOST 4 High speed USB 2.0,support U DISK and USB HDD
    1*TF CARD Support 1~32GB
    1*AV AV output
    1*SPDIF Audio output
    1*RJ45 10/100 BaseT
    Power DC Adapter ( 12V/1A)
    1*RF IN DVB RF IN
    1*RF OUT DVB RF LOOPOUT
    1*HDMI
    Tv Stuff
    Demodulation QPSK,16QAM,64QAM or 256QAM
    Forward Error Correction Rate
    1/2,2/3,3/4,3/5,5/6
    Guard Interval 1/4,19/256,1/8,19/128,1/16,1/32,1/128
    Bandwith 6/7/8MHz
    Input Input Frange range:54--860MHz Input Impedance:75 Ω
    Input Signal level: -84 dBm to 0 dBm (average power)
    ANT. Connector IEC TYPE, female Loop Outpur:IEC TYPE, male, should be F connectors (personal choice)
    Other Bits
    Other Functions IR Remote
    LED Indicator Power ON :blue; Standby :Red
    Mould Private tooling, Again
    Support most external 3G USB dongle
    DVB-T2 system standard:ETSIEN 302 755
    Support MPLP
    Mouse/ Keyboard: Support 2.4G wireless mouse and keyboard via 2.4G USB dongle
    KODI \DLNA \AirPlay \Google TV Remote \LAN \Miracast \3D moive Support
    DRM Optional: Microsoft Playready,Verimatrix ,Google Widevine
    Appliactions Browse all video websites online, support Netflix,Hulu,Flicker,Picasa,Youtube,Twitter ,Facebook,etc
    Apps: Apps download freely form Android market, Amazon App store etc
    Medium Local Media playback, support HDD, U disck ,SD card
    Talk online Support SKYPE video call , facebook,twitter,Netflix,Youtube, etc
    Others: Email,Office suit etc
    Package Contents
    1 x TV box
    1 x IR remote
    1 x HDMI cable
    1 x Power adapter 12v/2a (A right AC Adapter will be sent as your shipping country) (Better adapter for AU please)
    1 x User manual
    Not 100% myself with the specs as there is few models about.
    A little more info about this S805 at CNXsoft
    Cheers
      I like the concept and might be the ideal kind of replacement for ISP supplied did boxes as long as we see them with at least dual tuners.
        Or something to use on your 34 inch Dell monitor or two. Click image for larger version
          Awesome, and what sw do you use to combine two monitors into one seemless image.
            hello, here is my problem: I put the CCcam.cfg file in the USB key, I plugged in k1 S805 DVBS2 case, I type 111111, and when I press the yellow button to import the file, it shows me: file not bear .. !! Can you help me please ? thank you.
            Model: K1 DVB-T2
            System
            RAM DDRIII 1GB
            ROM Flash Nand 8GB
            Connectivity
            Wifi 2.4G WiFi
            Ethernet 10/100
            Bluetooth N/A
            Video Supported
            Resolution 1080P
            Ports
            1*AV AV output
            1*RJ45 10/100 BaseT
            1*RF IN DVB RF IN
            1*HDMI
            Tv Stuff
            1/2,2/3,3/4,3/5,5/6
            Bandwith 6/7/8MHz
            Other Bits
            Support MPLP
            Package Contents
            1 x TV box
            1 x IR remote
            1 x HDMI cable
            1 x User manual
              Which rooted firmware shoud I use it for this tv box? Cant turn wifi on...
                think you need to turn LAN off, which auto turns Wifi on, in android settings
                  Did you get cccam going?
