I have a generic CS918 device, which I connect to my lan either wired or wireless.
Recently, I incorporated an unmanaged switch (Netgear GS308) into my network, to tidy up.
My CS918 works great on wireless, and great if it is wired directly to the router. However, wire it to the switch and I get constant reconnects - every couple of seconds. No other devices are affected - I've tried swapping ports/cables etc. I have also attempted a static IP to see if this would help. Any ideas?
