M8 TV BOX No Wifi or Bluetooth
Hi guys, I bricked my M( TV Box (s802) and I unbricked it installing the probox2 rom, but now my wifi doesen't turn on. My bluetooth turns on but i can't detect any device. Using root explorer I haven't any wpa_supplicant.conf file, what i have to do? Please help meTags: None
Originally posted by neomode View PostHello,
I think you have a different Wifi, Bluetooth Version in your Box then the Probox2 have.
From the M8 there are different Hardware Versions.
The best you can do is open it up and make Photos of the PCB from Both Sides.
Then we can may Help you.
Neomode
I opened the box, here are some images
I have the same problem. Strange because I have m8s S812 and looks the same
here is my PCB : https://drive.google.com/open?id=0B8...mNFNWM3QTFoZDQ
Guest
I have the same problem- no wifi no bluetooth. And the pcb is the same as above kca-003 ver 1.0 date 150422. The only difference i have m8s with amlogic s812 cpu
nah same wifi chipset Neo
flash this rom http://www.solidfiles.com/d/6ed7b88a...2-20140929.rar
you may need to flash remote update depending on your remote you have round or 2nd gen squareBugs are Sons of Glitches!
JustMe
Guest
link is for s802
I will provide s812 is is s812s or s812 c?Bugs are Sons of Glitches!
JustMe
Guest
Originally posted by JustMe View Postlink is for s802
I will provide s812 is is s812s or s812 c?- S802 Good for 1080p and 4K video playback. Excellent performance with a quad core processor, Octa core GPU. Could be also used as a pretty good gaming platform. No HEVC support.
- S812 Same as S802 but adding H.265/HEVC video decoding up to 4K and Gigabit Ethernet. This makes it more future proof than S802, and it could potentially be used as a media center with a USB hard drive and Gigabit Ethernet connection.
So firmware s802 might work , but not use H.265 ? Am I wrong ?
If s812 has a Gigabit Ethernet...why Me and dincis1 have 100mbit ? Probably this is the fault of PCBs from m8.Last edited by hipisxbit; 11-02-2015, 14:18.
Guest
Originally posted by hipisxbit View PostHow to check the version of the S812 ?- S802 Good for 1080p and 4K video playback. Excellent performance with a quad core processor, Octa core GPU. Could be also used as a pretty good gaming platform. No HEVC support.
Guest
Originally posted by hipisxbit View PostNo, not yet. I was hoping that you do this Seriously what is waiting to answer JustMe , I think that's an expert on Android
There are currently 1835 users online. 6 members and 1829 guests.
