I've read there's anothe member with the same problem, so if someone finds out a solution it can be helpfull for anyone who may have the same problem. I have a Beelink x2 wich turns on, the light turs blue but the Tv shows 'no signal'. Someone has any idea to fix the problem? Thaks in advice.
Beelink X2 problem
Beelink X2 problem
Hi everyone,
Tags: None
Originally posted by Gennydess View PostI have flashed it, but still have the same problem!
Sorry for this bother.
Please help me show you TV model ID, we want to buy the same model to test .
HDMI display issue is the first important problem we want to update but always fail to get this type TV to test. We even go to the TV sales field to try kinds of TV.
BTW, would you help to check whether the blue led blinks every time press a remote key.
thanks
I had a very similar problem. I had set my X2's to 1080P/50Hz while they were connected to my computer monitor. When I moved the box down to my main TV and connected it, I got no picture. Brought it back to my computer monitor, and it worked fine. So, I went into the Display settings and change it to 1080P/60Hz, reconnected to my TV, and everything works great!
Turns out my main TV doesn't support 50 Hz. Make sure this isn't the issue... Try connecting the box to a computer monitor and see if it displays on that.
There are currently 3340 users online. 3 members and 3337 guests.
