OpenELEC 6.0.0 (stable) released for WeTek Play and WeTek OpenELEC
    The stable version is out!
    On OpenELEC.tv was released the new OpenELEC 6.0.0 for all supported devices, including WeTek Play and WeTek OpenELEC
    Update .TAR file: (Users which are running already 5.95.1, 5.95.2, 5.95.3, 5.95.4 or 5.05.5 version can use this .TAR to update NAND and SD-Card installation as well):
    Update
    NAND Install file:
    Download
    SD-Card Install file:
    Download
    You can check more here
    Best Regards
