PopMetal development board Rock-chip RK3288 operating systems supported Android, Ubuntu, and Chrome OS ? roms porting
    it posibile to porting ​roms from PopMetal development board Rock-chip RK3288 ?Click image for larger version
    PopMetal technical specifications:
    • SoC – Rockchip RK3288 quad core ARM Cortex-A17 processor @ 1.8Ghz with ARM Mali-T764 GPU with support for OpenGL ES1.1/2.0/3.0, OpenVG 1.1, OpenCL 1.1, DirectX 11
    • System memory – 2GB DDR3
    • Storage – 8 GB eMMC, SATA connector for 2.5″ HDD/SSD (TBC), and micro SD card slot
    • Connectivity – Gigabit Ethernet, 802.11 b/g/n and 802.11ac Wi-Fi, Bluetooth 4.0, GPS, and NFC. Two external antennas for Wi-Fi and GPS.
    • Video Output / Display Interfaces
      • HDMI 2.0 up to 4kx2k@60hz
      • VGA up to 1080p
      • LVDS
      • eDP (embedded DisplayPort)
      • MIPI DSI
    • Audio I/O – HDMI, 3.5mm headphone jack, built-in microphone, LINE IN, optical S/PDIF, audio output headers.
    • Camera – MIPI CSI connector, CIF connector
    • USB – 3x USB 2.0 host ports, 1x micro USB OTG port, 1x micro USB debug port
    • Debugging – Serial console via micro USB debug port
    • Misc – Home, Vol +/-, and power buttons, IR receiver, three jumpers
    • Power – 5V/3A
    • Dimensions – 15 x 9.2 cm
    http://wiki.chipspark.com/en/index.php?title=PopMetal
    ==PopMetal For Android==
    Android5.1 Android5.1 For PopMetal Development Board]
    http://en.chipspark.com/download/fil...opMetal-5.1.7z
    ChromiumOS Chromium OS image For PopMetal Development Board]
    http://en.chipspark.com/download/fil...opMetal.tar.gz
    Ubuntu Ubuntu For PopMetal Development Board
    Ubuntu image for PopMetal :http://en.chipspark.com/download/fil...al_20150706.7z
    username:ubuntu
    password:ubuntu
    PopMetal_Android_Kernel_git PopMetal_Android_Kernel
    https://github.com/RockchipOpensourc...id-kernel-3.10
    PopMetal_Ubuntu_Kernel_git PopMetal_Ubuntu_Kernel
    https://github.com/RockchipOpensourc...al-kernel-3.14
    i tested Android 5.1 PopMeta and Ubuntu , 1 sec boot img , not worked for my
      If you want to use this image with another box plug a phone charger on your mini USB in our or power the port with an of cable
      Sent from my GT-I9505 using Tapatalk
        Last part was meant to read phone charger or otg cable as well as the normal charger of course.
