Blue Times MX5 DEAD
    Blue Times MX5 DEAD
    Hello everybody, i have blue times MX5 TV box and 2 weeks ago it was have problem that when i turn it on its stick on ANDROID logo and dos not do anything other, i have contact seller and costumer support on bluetimes.com because i don't understand anything about flash and rom but no respond from them.
    then i start to look how to fix it and i found some file its called (Rikomagic S8B_20131107) and they say i should copy that to some flash memory and connected with the box and make recovery or something like that, i have follow everything and after its install the box is restart and after that nothing show in the screen, i turn it off and on many times but still nothing on the screen, even HDMI cable can't read it, sound like there is nothing connected with TV.
    please help if you can and explane to me what i should do because i can't find anything and i don't know even what i should serch about.
    Thank you
    Any help pleaseéeeeeee
      Hello Morio2, I do not own this box and have no experience with it. So I cannot help you specifically.
      I saw a thread where your problem is discussed. You will need to read through it to make sure it applies to your box. There maybe others too.
      When searching here or on Google, try the search term, " bluetimes mx5", also.
      Good luck. I will check back to see how it's going, and try to help further if I can.
        Thank you so much Riscy Dude , I will do what you said, and i hope i can find something helpfull.
          Anyone have idea?
