Just when you thought the Square Box with the round corners was gone.
- Android 5.1
- CPU RK3368 Octa-core ARM Cortex-A53 up to 1.5GHZ (DVFS),64 bit
- GPU PowerVR G6110 GPU up to 700MHz (DVFS),OpenGL ES3.1, OpenCLES3 and DirectX 9.3
- 3D Graphics OpenGL ES 3.1/3 and Directx9.3
- RAM DDRIII 2GB
- ROM EMMC 8GB
- Communication
- Wifi Connectivity AP6330 (Support 802.11 a/b/g/n Dual Band Wi-Fi 2.4GHz&5GHz)
- Ethernet 10/100 BaseT
- Bluetooth V4.0
- Standard HDMI 2.0
- Standard HDMI 2.0
- 2*USB HOST High speed USB 2.0,support U DISK and USB HDD
- SD CARD Support 1~32GB
- AV Standard resolution AV
- SPDIF Digtal audio output
- RJ45 10/100 BaseT
- Power 5V 2A
