M8S+ Android 4K Mini Media Player Amlogic S812 Quad Core 2.0 GHz 4.4 HD 2G/8G 2.4G/5G Gigabit LAN WIFI BT4.0
    • Android 4.4 KitKat
    • Amlogic S812 Cortex A9r4 2.0 GHz
    • Octa-core Mali-450MP @ 600MHz; Hardward 3D graphics acceleration
    • DDR3 2GB
    • Rom 8GB
    • SD Card supports up to 32GB
    • Support 802.11 b/g/n Dual Band Wi-Fi(2.4GHz/5GHz)
    • 100/1000M
    • Bluetooth V4.0
    • Standard HDMI female, 1.4b
    • 2 x USB 2.0,;SD/SDHC, SPDIF
    hmm old news i can post picture of that box too nothing special been out for while.only difference is teh gigabit ethernet
    Bugs are Sons of Glitches!
    JustMe
      True may create some interest, or comments
      please post that's the idea create some talk and comments, how it performs.
      Cheers
        been many talks of it prior
        http://freaktab.com/forum/tv-player-...-5-1-1-rom-wip --- first page
        http://freaktab.com/forum/tv-player-...79-bricked-m8s
        JustMe
          IMHO this box is crap. Have only found one firmware that works and it runs Kodi horribly. I have brciked and unbricked this pos 4 times. Just about ready to chuck it in the trash.
            Pass on any information you have to others if you like, may help.
            Lets know the firmware you found and unbricking procedure may help other.
            A bit of interest may get others working on more firmware
            Cheers
              See post #4http://freaktab.com/forum/tv-player-...79-bricked-m8s
                Make sure it has CE if you're going to try selling it at least in some countries, last we checked non of them did.
                Team UX
                http://www.ultimatexbmc.com/
                http://www.freaktab.com/showthread.p...-ULTIMATE-XBMC
                  This firmware (lolipop) seems to be more stable and runs KODI well. Wifi not so good. Will try ethernet on the weekend. http://chinagadgetsreviews.com/downl...8s-tv-box.html
                    Always no statusbar or navigation bar : this is a problem.
                      So I'm starring down the barrel of no notification or status bars.
                      Also I can only get a recent app list by using kk launcher I think, can't rightly remember which one got that to work.
                      Any work around or anything, even a third party app that may poke a hole through this thing and get me my notifications?
                      I managed to get the notification header section to appear using app full!screen but there are no notification updates.
                      Any info or any direction would be great.
                      P.S. mine is 5.1.1
                        I ordered 5 boxes from Acemax with openelec, after a few days or weeks of use, the box gets stuck on the Openelec splash screen, I used KII-ota-20151030.zip and then reflashed to openelec OpenELEC-Amlogic.arm-M8SPlus-6.0.0-update.zip but still after a few days, three boxes came back to me with the same problem.
                        The boxes runs fine after reflashing but after few days and some after two weeks, it gets stuck on the openelec splash screen after the ROM logo.
                        here's pictures of my main board
                        any help much appreciated
                          Hallo to all! I have the same box, and i tried to install openelec but i soft brick it. I tried many firmwares to find the appropriate firmware for restore without any luck.
                          Can anyone please help me?
