I managed to install your DEB completely without breaking my LXDE/Xserver stuff.
sudo apt-get install lsb-release wget http://mac-l1.com/v0.1.2/machybris-rk3188_4.4.2-0.1.2_armhf.deb sudo dpkg -i --force-all,confnew machybris-*_armhf.deb sudo apt-get install -f
UMP: ump_arch_open() failed to open UMP device driver
hwc already has procs! now overriding...
width: 1024 height: 600
ERROR: failed to open gralloc: (Operation not permitted)
test_hwcomposer: eglplatform_hwcomposer.cpp:33: void hwcomposerws_init_module(ws_egl_interface*): Assertion `0' failed.
I added fb=vc:64-63 to my kernel cmdline, but I still have a framebuffer console while booting, not sure if this is normal?
I had the sunxi-mali driver to work so EGL/GLES drivers are not necessary to me, as I have already working driver directly in linux.
I'd like to strip the EGL/GLES part of the package. Would you mind guiding me in the right direction?
According to " cat /var/lib/dpkg/info/machybris.list | egrep 'EGL|GLES|egl|gles' ", I removed everything related to EGL/GLES:
/usr/local/lib/libGLESv2.so.2.0.0
/usr/local/lib/libEGL.la
/usr/local/lib/libhybris-eglplatformcommon.so.1.0.0
/usr/local/lib/pkgconfig/egl.pc
/usr/local/lib/pkgconfig/glesv2.pc
/usr/local/lib/pkgconfig/hybris-egl-platform.pc
/usr/local/lib/pkgconfig/glesv1_cm.pc
/usr/local/lib/pkgconfig/hwcomposer-egl.pc
/usr/local/lib/libGLESv1_CM.so.1.0.1
/usr/local/lib/libGLESv1_CM.la
/usr/local/lib/libhybris/eglplatform_fbdev.la
/usr/local/lib/libhybris/eglplatform_hwcomposer.la
/usr/local/lib/libhybris/eglplatform_null.so
/usr/local/lib/libhybris/eglplatform_null.la
/usr/local/lib/libhybris/eglplatform_hwcomposer.so
/usr/local/lib/libhybris/eglplatform_fbdev.so
/usr/local/lib/libhybris-eglplatformcommon.la
/usr/local/lib/libGLESv2.la
/usr/local/include/EGL
/usr/local/include/EGL/eglmesaext.h
/usr/local/include/EGL/eglext.h
/usr/local/include/EGL/egl.h
/usr/local/include/EGL/eglplatform.h
/usr/local/include/EGL/eglhybris.h
/usr/local/include/GLES2
/usr/local/include/GLES2/gl2platform.h
/usr/local/include/GLES2/gl2.h
/usr/local/include/GLES2/gl2ext.h
/usr/local/include/hybris/eglplatformcommon
/usr/local/include/hybris/eglplatformcommon/nativewindowbase.h
/usr/local/include/hybris/eglplatformcommon/support.h
/usr/local/include/hybris/eglplatformcommon/ws.h
/usr/local/include/hybris/eglplatformcommon/hybris_nativebufferext.h
/usr/local/include/hybris/eglplatformcommon/eglplatformcommon.h
/usr/local/include/GLES/glext.h
/usr/local/include/GLES/gl.h
/usr/local/include/GLES/glplatform.h
/usr/local/include/GLES/egl.h
/usr/local/bin/test_egl
/usr/local/bin/test_egl_configs
/usr/local/bin/test_glesv2
/etc/profile.d/libhybris_path_eglplatform.sh
/usr/local/lib/libEGL.so
/usr/local/lib/libhybris/eglplatform_surfaceflinger.so
/usr/local/lib/libhybris/eglplatform_surfaceflinger.la
/usr/local/lib/libEGL.so.1
/usr/local/hybris/lib/libGLESv1_CM.so
/usr/local/hybris/lib/libEGL.so
/usr/local/hybris/lib/libEGL.so.1.0.0
/usr/local/hybris/lib/libGLESv2.so.2.0.0
/usr/local/hybris/lib/libhybris-eglplatformcommon.so.1
/usr/local/hybris/lib/libEGL.la
/usr/local/hybris/lib/libhybris-eglplatformcommon.so.1.0.0
/usr/local/hybris/lib/libGLESv1_CM.so.1
/usr/local/hybris/lib/libGLESv1_CM.so.1.0.1
/usr/local/hybris/lib/libGLESv1_CM.la
/usr/local/hybris/lib/libhybris-eglplatformcommon.la
/usr/local/hybris/lib/libGLESv2.la
/usr/local/hybris/include/EGL
/usr/local/hybris/include/GLES2
/usr/local/hybris/bin/test_egl
/usr/local/hybris/bin/test_egl_configs
/usr/local/hybris/bin/test_glesv2
I also commented the kernel modules things (mali, ump, mali_drm, drm) from the boot script (/usr/local/share/libhybris/libhybris.sh) to keep my mali kernel modules and removed the # set EGL_PLATFORM to default part
Is there anything else to remove? Is there anything I should keep to be sure?
Also, I'm not able to 'make' your player example:
h264player.cpp
collect2: error: ld returned 1 exit status
Thanks for your support and your super work!
Sorry if I'm still a linux-newbie!
Jonathan
