mackodi/macspmc: KODI and SPMC on LINUX for rockchip devices
Originally posted by McAron View Posthm. I saw here http://www.seeedstudio.com/wiki/imag...etail_V1.2.pdf that:
Does it mean that i can use hardware for rgb2yuv, like you in h264recorder?Support my work to make you a better multimedia experience...
And Donate...
Originally posted by McAron View Postis it possible to convert i420 to nv12 using RGA on rk3188? Can i use your rga_blit function for it?
formats are specified in androids hardware/libhardware/include/rga.h
RK_FORMAT_YCbCr_422_SP = 0x8, RK_FORMAT_YCbCr_422_P = 0x9, RK_FORMAT_YCbCr_420_SP = 0xa, RK_FORMAT_YCbCr_420_P = 0xb, RK_FORMAT_YCrCb_422_SP = 0xc, RK_FORMAT_YCrCb_422_P = 0xd, RK_FORMAT_YCrCb_420_SP = 0xe, RK_FORMAT_YCrCb_420_P = 0xf, hope this helps.Support my work to make you a better multimedia experience...
And Donate...
Thank you! I will try it today. But what means "frame memory is 16 bit aligned in width and height." Does it mean that frame memory size(in bytes) should be dividable by 2? For example for l420 it is 12 bytes per pixel needed , than frame memory size is fm_size=width*height*3/2 bytes. So requirement is fm_size to be dividable by 2 ?
I have tried your function, but with no luck, so i wrote my own simple colorspace converter using function rga_nv12torgb565 from https://github.com/Nu3001/hardware_r.../CameraHal.cpp
Source and binary are here: https://github.com/McAronDev/RK3188_colorspace_convert
Results:
NV12toRGB565 produces good frames but with black areas in random location. I can not understand why. I have not changed rga_nv12torgb565 code.
NV12toI420, NV12toNV12 added for testing. Both produces green frames with image contours.Last edited by McAron; 13 August 2016, 02:44.
Originally posted by McAron View PostI have tried your function, but with no luck, so i wrote my own simple colorspace converter using function rga_nv12torgb565 from https://github.com/Nu3001/hardware_r.../CameraHal.cpp
Results:
I tried it with some different code and got the same black areas/stripes that you mentioned. Have you already found a solution?
And Donate...
Results:
maybe this helps in solving the black stripe issue.
and it also seems that rgb2yuv mode is possible, for instance for encoding.
hope this helps!
cheers -- mac-l1Support my work to make you a better multimedia experience...
And Donate...
There are currently 5857 users online. 1 members and 5856 guests.
