MXIII 2G/8G bricked - red light, nothing more
    Hi all
    I have a problem with my mxIII box 2g/8g box (S802, AP6330 wifi).
    Story starts few days ago, got powercut and box didn't want to boot up (bootloop on mbox logo). So, I tried to put in the recorvery mode - succes.
    I'd put 114k4 firmware on sd card, go to recorvery mode with toothpick method. Box started to flashing automaticly. After all didint reboot, even after 5 minutes.
    And now, i cant get it into recorvery mode, on display dont see anything (no signal). When I put the power cord and press on/off button led goes red and nothing more (no matter that I'm holding reset button, or not - and reset button is ok, yesterday I'd put box into recorvery mode this way).
    My only hope is that windows recognise this device via OTG-USB cable. Tried to flash with USB burning tool but no effect - depends on version of usb burning tool stops on
    2% with [0x11010401]USB error occur when check DDR run at RomCode
    or about 3-5% with [0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
    Drivers I have from usb burning tool instalation.
    Windows recognise this device as M8-CHIP when gets drivers first time and after installing drivers recognise as Worldcup device.
    I spend yesterday afternoon and half of today on reading tips, and trying to flash from USB or put box into recorvery - no luck ;c
    I have the same box etc...
    Try the Tronsmart 115k4 Kitkat Build...
    Tronsmart is a leading brand innovating cutting-edge audio products such as speakers & headphones with premium sound quality.
    or RemiX 115k4 Kitkat Build
    OpenELEC
    S82 arm versions (ones that i have checked work on the box)
    5.0.8
    5.95.3.4
    5.95.5.2 (latest)
    I hope the info above helps
