First I extract the parameter file using start = 0 and count = 2 and then start to extract the other parts according to the parameter file. However kernel seems to be empty, and boot contains the parameter file from time to time . Only system seem to contain something, but have no idea if it is correct what is inside. Is there any other way to make this dump? Or it there any kind of protection?
I intend to put wasser lolipop on it, but want to be able to came back if possible.
