-The first question is: which is the best rom? I know it depends on wifi hardware but i suppose that gearbest send only original mk808b plus with ap62xx module.
The latest available stock firmware is 112k4 (october,2015) but all the rom posted here are based on older version
-The cec function works with newer firmware? Or only requires a new hdmi cable?
-does it support netflix HD? I've read that the rom with CM has included widevine so reneaming the pcstick is possible to play it?
-I know it's a 27/$ android tv so i can ask a lot of things at this device but does it support 23,976 with kodi?
-how works openelec beta rom?is it stable?
-how every rom manages the ram? I mean, looking at youtube videos with the stock rom the ram is always at about 70% usage(i know there is free-ram button),is it a big problem or there is any script/tweak to apply?
Thank you in advance
From italy
