I'm using OpenELEC-Amlogic.TV110.arm-5.95.2 on my S805 device.
I have a Mygica T230 TV tuner which is only supported on Kernel 3.19, since this is Kernel 3.10 it needs drivers. I looked at the drivers seem to be there but tvheadend doesn't see the tuner.
[ 4814.995650@2] usb 2-1.4: new high-speed USB device number 9 using dwc_otg [ 4815.096587@0] usb 2-1.4: New USB device found, idVendor=0572, idProduct=c688 [ 4815.096619@0] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 4815.096632@0] usb 2-1.4: Product: USB Stick [ 4815.096644@0] usb 2-1.4: Manufacturer: Max [ 4815.096656@0] usb 2-1.4: SerialNumber: 080116
OpenELEC:/var/media/mmcblk0p1-mmc-SD02G_0xa7060d97/test # lsusb Bus 001 Device 008: ID 1a40:0101 Terminus Technology Inc. Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 009: ID 0572:c688 Conexant Systems (Rockwell), Inc. Geniatech T230 DVB-T2 TV Stick Bus 002 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver Bus 002 Device 003: ID 1a40:0101 Terminus Technology Inc. Hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub OpenELEC:/var/media/mmcblk0p1-mmc-SD02G_0xa7060d97/test # lsmod Module Size Used by si21xx 8360 0 cbc 2022 0 dhd 626113 0 cfg80211 204928 1 dhd wifi_dummy 594 0 mali 162645 5
