New Cs918 type
I don't have it. I was foolish in thinking I could flash any CS918 firmware at the time so mine is also in a none working state. There are a few roms that can be flashed but the Wifi and bluetooth won't work.
Anyhow after a week or so of searching and trying many roms I can tell you there isn't one out there yet that workks for this CS918 for some reason.
I've contacted Banggood.com and they said yesterday they have contacted the supplier to ask for the rom and will email me when they get it.
I didn't buy it from them so not sure if it will happen but worth a shot and if it does and it works, I'll upload it to the cloud and post a link.
Or post here if you do find one
Hi, I bought 2 of these boxes and tried to update the firmware on only one of them. ended up with no wifi and remote not working. I have been trying to get the rom off of the other box, but have not been sucessful because when I flash the backup files and boot the box it says I am missing the external sdcard partition and I can't find instructions for extracting that partition using the dumptool. Anyone have any idea how to get that partition using the dumptool, that would solve the problem.
After battling for two weeks with Banggood and their crappy firmware hosting site I couldn't get a working firmware from them.
Tried for a few days tring to get the firmware hereinsd kindly uploaded but couldn't get that going either. Tried mashing parts of that with other firmwares.
Contacted Geekbuying now a s a last resort but douubt they will help but if I get it going one day I'll upload the firmware.
I contacted my vendor and requested the firmware for my device. He gave me a link to download it and I installed it and everything as far as hardware goes, works just fine. The box has crashed and rebooted itself several times though. I can confirm however that this firmware is not the exact one that came installed on the box originally. Hopefully we can use it though to construct a version that is stable.
Here is the link.
hereinsd Awesome...Working...so far
I'll test to see if I get any crashing but at least wifi works.
Could your crashing be down to the wrong kernel being installed as when I extracted the firmware I did not see any kernel so it probably just uses whatever was on last.
Try flashing the kernel from your other backup if you haven't already.Last edited by blinkone; 08 December 2015, 18:07.
Originally posted by hereinsd View PostI contacted my vendor and requested the firmware for my device. He gave me a link to download it and I installed it and everything as far as hardware goes, works just fine. The box has crashed and rebooted itself several times though. I can confirm however that this firmware is not the exact one that came installed on the box originally. Hopefully we can use it though to construct a version that is stable.
Here is the link.
https://www.dropbox.com/s/0snj6wrs53...-15.0.zip?dl=0
But I have a problem. I got what penguins on the screen. Tell me what to do, or to reset the firmware. Thx in advance.Last edited by FrogyRU; 01 December 2016, 15:20.
There are currently 1802 users online. 1 members and 1801 guests.
