again this went smoothly,
Checked the log files and all seemed well, the format, no errors, or bad blocks showing
Left it running for a while, with a test app running which re-booted a few times and still all seemed well, that is until I tried to install some apps. Installed Gmail, facebook, taptalk, messenger, bbc news/weather and then after waiting for the installs to finish I shutdown waited a few mins and restarted, only to find that first off I was stuck in the rileyrom boot loop screen, on the second attempt I found that the apps failed to start with multiple errors, (acore,gapps,play) to name a few.
Basically I left with tablet which is only good for watching movies of my usb card, or browsing the internet, as every time I have tried to install an app it has led to me having to re-flash.
I'm guessing the nand memory is screwed, with no way of being able to repair it
