Z4 RK3368
Originally posted by cuboide View PostHi all, I just bought a Z4 tv box and I'm trying to use a logitec quickcam pro 9000 with skype. The webcam has a built-in mic and connects via usb port. I cannot get the microphone working at all. Do you know if there is a way to activate the mic in the rk settings? thanks!!
Originally posted by privet View PostI think that Z4 is the same as EKB368 http://freaktab.com/forum/tv-player-...rmware-support
That's why it's best to avoid it.
Maybe the firmware from Tronsmart Orion R68 Meta will work well on Z4, the hardware is the same AP6335, 2g/16G, CPU RK3368, LAN 100/1000M
Originally posted by vinaysharma76 View PostCan any one help on how to root and install custom recovery on Z4 (TWRP or something else)
Easy. On your Android phone, just download Kodi from Google Play Store & activate UPnP / DLNA in its settings. Use already installed Kodi in your TV box & add use UPnP devices in Add Video source. Same in iOS too. My Andoer Z4 based on RK3368 working fine BTW.
Inclined to update to a future unified ROM for better performance / new features but satisfied at the moment. :-p
There are currently 4425 users online. 0 members and 4425 guests.
