If anyone have question just ask
!Google TV Apps Can Be Downloaded From My Website!
My website:
www.apkfreak.com
Facebook:
https://www.facebook.com/Apkfreak
Rockchip Batch Tool
Beta:
MK808
Dev-Host V2.2.4 720p
Cloud FreakTab V2.2.4 720p (Mirror)
MK808B
Neo G4
Neo X5
Stable:
MK808
Dev-Host V2.2.3 480p
Dev-Host V2.2.3 720p
Dev-Host V2.2.3 1080p
MK808B
Neo X5
Neo G4
Cabletech
CWM
Available soon...
NFS Kernel (Android 4.1.1):
Dev-Host
FreakTab Cloud (Mirror)
I cant test this kernel becouse my mk808 was swiming in water so please post fedback on what devices its working and on which its not working.
Post abouth wifi etc. it will probably work on RK901 wifi chip devices.
If this kernel dont work for you, you can always go back to stock without loseing any data.
Use bob tools to flash just the kernel.
You can mount NFS share using Busybox, just download any terminal app and paste this command (edit remote nfs directory to look something like this 192.168.x.x:/xxx acording to your NAS nfs share IP):
su busybox mount -o rw,intr,soft,nolock,nfsvers=2 [remote NFS directory] [local directory]
To Mount at system startup you can use a init.d script or add a code abowe to /system/etc/install-recovery.sh file.
It will mount to /system/mnt/NFS you need to edit script to add your shares (Use Notepad++)
Script:
Dev-Host
MK808 USB BT Kernels:
Dev-Host 720p
Dev-Host 1080p
Modules RK3066:
Dev-Host
rtl8711.ko; nls_utf8.ko tun.ko; ath3k.ko; hci_vhci.ko; bfusb.ko; bcm203x.ko; btmrvl.ko; btmrvl_sdio.ko; ath.ko; plusb.ko; pl2303.ko; gspca_main.ko ;gspca_sonixj.ko; sunrpc.ko; auth_rpcgss.ko; lockd.ko; r8712u.ko; mcs7830.ko; rt5370sta.ko; rtl8192cu.ko; cp210x.ko; ftdi_sio.ko; nfs.ko; ntfs.ko; 8723au.ko; cx82310_eth.ko; dm9601.ko; smsc75xx.ko; smsc95xx.ko
changelog:
V2.2.4
-based on 20/05/2013 firmware
-rooted with latest SuperSU
-aded:
MK808 1920x1080_24 (only 2dark4you kernel)
Neo X5 1920x1080_24 1920x1080_25 1920x1080_30
-nfs support only on Neo X5
-applied new set of FFMPEG library
-updated libstagefright library
-support the new Gen.2 RKremote controller app
-added RKGameControlSetting for game touch profile setup
(external install, if you want it install eHomeMediaCenter_box and RKGameControlSettingV1.0.1 on your device and RKRemoteControlGeneralCastV2.0.2 on your phone)
-fixed some strings in Settings and firmwork-res for better look.
(example: was "fast", now "Fast")
-visual changes (wallpaper, status bar, pointer, shoutdown menu)
-init.d support
-seeder app to speed up things (entropy generator)
V2.2.3
-bug fixes
-fixed 2dark4u kernel support (if you want you can flash alex kernel now)
-init.d support
-separate modules
(now only btusb.ko; cifs.ko; md4.ko; xpad.ko; virtual_touchscreen.ntts.ko are loaded at startup)
-modules package
(if you want tu use any of additional module, just extract the "Modules RK3066" package
chouse module you want to be loaded at startup, rename it to "custom.ko" and put it in the root of internall sdcard
it will auto load on next boot.
you can put up to 3 custom.ko (custom.ko; custom1.ko; custom2.ko)
-fixed wifi for mk808 (becouse of thease i need to create separate .img for mk808/mk808b)
-usb bt for mk808 will be optional (if you want usb bluetooth support flash USB BT Kernel using rktools or finless tools)
V2.2.2
-better performance
-faster boot up
-youtube for gtv updated to 1.6
-tv launcher
-build.prop fixes
-fixed touch emulation
-new modules loaded at startup:
8723au.ko cx82310_eth.ko dm9601.ko smsc75xx.ko smsc95xx.ko
V2.2.0
-NeoX5 +NeoG4 Support
-based on 26.03.2013FW
-rooted
-build.prop changes
-gameloft games fix
-logitech C series webcams best suport
-virtual touchscreen suport (apps like sixaxis can mapp touch events, degre need to be changed to -90 in sixaxis settings)
-usb bluetooth dongle support for mk808 (working randomly)
-new bootanimation
-stock kernel (you can flash any other kernel but bluetooth dongle will not work anymore)
-app space 2gb
-more space on launcher screen
-cifs auto mount on startup (edit /system/etc/install-recovery.sh and put there your server ip, username, etc. change permisions to rwx --- ---)
-libstagefright.so (new for better xbmc and other players compatibility)
-youtube for gtv
-wallbase (tons of nice wallpapers)
-(1080p) LCD Density 240
-(480p) fast as hell;p for thous that dont need hd
-added Android Tuner
-build.prop tweaks (wi-fi, ui, and other tweaks)
-es explorer (manage your files with best file manager, auto apk install)
-deleted useless aps
-fixess i dont remember;p
-modules loaded at startup:
btusb.ko xpad.ko md4.ko cifs.ko rtl8711.ko nls_utf8.ko tun.ko ath3k.ko hci_vhci.ko bfusb.ko bcm203x.ko btmrvl.ko btmrvl_sdio.ko ath.ko plusb.ko pl2303.ko gspca_main.ko gspca_sonixj.ko sunrpc.ko auth_rpcgss.ko lockd.ko r8712u.ko fakeinput.ko mcs7830.ko rt5370sta.ko rtl8192cu.ko cp210x.ko ftdi_sio.ko nfs.ko ntfs.ko virtual_touchscreen.ntts.ko
install:
-unpack arhive (anywhere)
-start RKBatchTool.exe
-put mk808 into flash mode (pres hiden buton and conect mk808 to pc, use usb otg port)
-instal proper drivers when windows ask (drivers are in \Rockchip_Batch_Tool_v1.5\Rockchip_Batch_Tool_v1.5 \RockusbDriver)
-when you wil see number 1 in green box selec "..." button in right top corner of RKBatchTool
-navigate to MK808 Hybryd FW V2.1.2.img
-pres restore button in RKBatchTool
after instal:
thats the things to do aftrer yoy install your rom o mk808.
-first bootup will be slower then the next one (android is setting ui)
-after boot wait about 3-5 minutes and reboot the device
-go to settings>developer options:
-change all animations to 0.5x
Thanks to:
-2dark4u
-finless bob
-kizs
-minix
