need wifi module for AP6181 chipset
Hi, I just bought a china brand android mini pc.. It's powered by Rk3066 processor, 1gb of ram, 4gb internal storage.. I just flashed it with finless 1.8 rom that specified for ug802.. And the wifi not working.. After I open up the casing, I found that it using AP6181 wifi chipset..can anybody here compile that wifi modules for me? Thanks.Tags: None
do you still have this stick? hope this helps if you still have it.
i also have clone rk3066. with 2 nanya memory. using sk hynix nand. and ap6181 wifi only. no bt.
cover case looks like mk808 but is not. i bricked it using mk808 fw because my nand chip is hynix.
but i got it working using rikomagic fw : mkIIIs8b_ap620_141230_v4.4 i found on chinagadgetsreviews.com
http://chinagadgetsreviews.com/downl...-tv-stick.html
before jellybean 4.2.2 and it's now kitkat 4.4.2 and works great and smooth!
but there is a bug on display settings. the screen scale does not save after reboot. i'm looking for this scale fix when i saw this thread.
There are currently 3685 users online. 0 members and 3685 guests.
