[HELP] R8 TWRP recovery
Originally posted by afgp87 View PostHello any ideas were in can get TWRP please help
no my friend i put recovery.img in the sd card but the box don't star the twrp i have this box http://www.gearbest.com/tv-box-mini-pc/pp_254173.html i really need help i will appreciate if u can help please
afgp87, get a toothpick.
Assume you have a valid image of TWRP
1) Unplug the power from the box (make sure the recovery.img is on the root of the SD card)
2) Insert the toothpick into the A/V port and press. You should feel the switch inside the hole depress.
3) Plug the box back in while holding the toothpick.
4) Release the toothpick after seeing the boot screen.
4) The box should power up to the TWRP screen.
cwh
There are currently 2375 users online. 0 members and 2375 guests.
