MXIII-G remote re-Program
    Hi guys,
    I have an MXIII-G with android 5.1.1 and I was wondering if there is a way to reprogram the red blue yellow and green buttons of the remote. I want to be able to use them in stb emulator. Is there a conf file that can be edited to change the remote shortcut buttons?
    Sent from my SM-G900W8 using Tapatalk
      Originally posted by mtrmtr
      Hi guys,
      I used external keyboard helper pro to open my prefered music/video/radio app, but i had to disable the respective stock app.
      Gesendet von meinem LG-H815
        How do you disable the stock app?
          Settings>Apps>All>AOSP Keyboard>Disable
          Once done, simply re-enable and your default keyboard will be External Keyboard Helper Pro, or which ever replacement you use, and you'll still have the AOSP as a back up.
          Currently Inactive on Freaktab.com
          I use: MK903V | MELE F10 Deluxe | Roku 3600R
          RIP: MK808b | MK809III | PIPO M9 Pro
            It was not the keyboard app i had to disable, it was the stock music, video... apps previously assigned to the key. But either the way described via apps menu or, as i did, freeze via titanium backup.
              Ah, sorry, did not understand the question.
