Amlogic M9+ S905 Android 5.1 4K Quad Core 1G/8G 802.11b/g/n, BT4, 10/100 LAN HDMI 2.0 H.265 Miracast DLNA Dolby, DTS
    Amlogic M9+ S905 Android 5.1 4K Quad Core 1G/8G 802.11b/g/n,BT4 , 10/100 LAN HDMI 2.0 H.265 Miracast DLNA Dolby, DTS
    • Operating System Android 5.1 Lollipop
    • CPU S905 Cortex A53 Processor 2.0GHz
    • GPU Penta-Core ARM Mali-450
    • RAM 1GB DDR3
    • ROM 8GB NAND FLASH
    • IEEE 802.11b/g/n
    • Lan 10/100M
    • Bluetooth V4.0
    • HDMI 2.0
    • Ports 4*USB, 1*HDMI, 1*RJ45, 1*SD, 1*AV, 1*DC in, 1*SPDIF
    • Packageower Supply DC 5V/2A
    • Whats in the Box
    • 1 x Media Player
    • 1 x IR Remote control
    • 1 x HDMI cable
    • 1 x Power adapter (A right AC Adapter will be sent as your shipping country)
    • 1 x User manual
    Cheers
    yes
    so i have this thing
    so far everything works except trueHD and DTS HDMA (most of the time)
    i had id working once for some reason
    unfortunatly i had no idea what i was doing (rtfm we do when we can not fix it by thinking for ourselves)
    anyway...
    I have taken this box apart and made detailed photos of the insides here;
    https://drive.google.com/drive/folde...kVPTWE2SldxNk0
    although i know its a box without much (no) support i would like to know if there is firmware which is compatible with this one
    P.S. the aluminium heatsink was put on by myself
    /edit
    i did some more researching and it looks like the box has the same PCB as the rikomagic MK06
