I thought the power supply was failing, but it looks like the power is fine. The box powers on, but there's just no video output.
It "feels" like it is doing a boot sequence too - if press the power button on the side of the "box", the front light goes red, then blue.... and after a couple of minutes, I can press the power button on the remote and it will toggle back and forth between red and blue (presumably "on" and "standby".... the most I manage to get in terms of HDMI response is a flicker of acknowledgement that there's an input, but but by the time it has switched over to the source, there's nothing and it just says "NO SIGNAL".
I've tried it on my little old 22" LG TV/monitor and 46" Philips "8007", both 1080P capable.
I've also tried it with a variety of HDMI cables (from TinyDeal specials to SuperFi and QED reference).
I'm pretty sure I've ruled out the TV's / cables.
Are there any other tests / checks worth doing?
Slightly at a loss as it was a really neat little, reasonably powerful little TV box, but pretty much useless now.
