MOREFINE M1 Windows 8.1 Android 4.4 PC Dongle Quad Core Intel 3735F 1.8GHz 2G RAM 32G ROM Wifi Bluetooth White
    MOREFINE M1 Windows 8.1 Android 4.4 PC Dongle Quad Core Intel 3735F 1.8GHz 2G RAM 32G ROM Wifi Bluetooth White.
    A handy small device turn that old LCD monitor into a a standalone unit
    • MOREFINE M1 is a smart Streaming Media Stick with Windows 8.1 OS (Authorized Licensed).
    • Once connected this player to the HDMI interface of TV, it will converts the regular TV into a Smart TV which likes a PC.
    • CPU: Intel Atom 3735F up to 1.8GHz
    • Intel HD Graphic(Gen7) GPU
    • Dual OS: Windows 8.1 with bing,Android 4.4
    • DDR3 2G RAM + 32G ROM
    • Bluetooth 4.0 function
    I see firmware for it, but updates require usb hub and usb memory stick.
    I'm seriously interested in either Win8 or dual boot intel stick. Under $100 USD, do you recommend this? There is also Wintel W5. And I saw a few with a fan. Any limitations or downside with them?
    Currently Inactive on Freaktab.com
    I use: MK903V | MELE F10 Deluxe | Roku 3600R
    RIP: MK808b | MK809III | PIPO M9 Pro
      Yes same with my Teclast Tablet, plug in a hub and a usb keyboard and a stick....but it works all ok in that situation.
      I cant see why not, lots about to look at, I have yet to ever use a stick type dongle.
      Hidden behind the TV may be a problem, but then you can slip it into you shirt pocket and take it any ware.
      As seen with most of the box type players with same specs, Heat can be a problem pending on the what your doing with the device.
      Cheers
        I wonder if you can restore via usb card reader and use otg for remote. Just format for Android first, then use same card formatted for Windows next.
