[Tutorial] Easy root method for Lollipop RK3368 Players (no iRoot)
Guest
Originally posted by pepvk0 View Post
Originally posted by dincis1 View PostFirst connect box to pc with otg cable, then press reset button on your tv box and while keep pressing reset button apply power to tv box. Everything should be ok
But when I try to install the SuperSU binaries in TWRP it gives me back lots of errors about not being able to find/recreate/mount various partitions. When it's done it says succesfull, but it doesn't seem to be; no root access. I would post the log file but I can not mount the external SD. When I go into the "mount" menu, all I can mount is USB Storage; no cache, no data, no system, no internal SD, no external SD.
Guest
Thanks a lot. Forgot about the reset (/volume) button trick, been a while since I flashed my iFive X2 tab. Mine (RK8, brand unknown) actually powers up through the usb lead (usb-a male to usb-a male), no need for dc adapter to start up. But it did start up as a LOADER device. Flashed the TWRP to it and now it starts up in TWRP if I use the toothpick (took some googling to find out the button was behind the 3,5mm jack).
Originally posted by solo7777 View PostI have a Beelink i68 on 205L and I successfully flashed Abduls TWRP on it using the instruction in post #1.
hi solo7777 maybe you can help me, I own a i68 and I also have tried the instructions in post 1. I have tried with all 3 recovery images listed in post 1. All of them are flashed with OK results. But I am not able to get my box into recovery mode. No matter how I try to do it, the box always starts into flash mode. I have used apps that start into recovery mode and I have also used the hardware method pressing power on first and then holding the reset button. And these methods all several times, and all with the same results. It looks to me like the box cannot enter recovery mode. Or I am doing it the wrong way.
Any help will be much appreciated, TIA.
I got it using this firmware: http://freaktab.com/forum/tv-player-...plant-your-rom
It includes TWRP and installs it on first run, and from then on all seems OK, now I can enter recovery as expected...
hello androidgadget11,
My tv box is I71S second generation, also RK3368 chip , and now I have to extract recovery partition, you compile R68 brush into the TWRP, does not work, please help me, help me adaptation under TWRP, can it ? Thank you!Android Tool Release v2.35 extract partition I uploaded to the network disk https://yunpan.cn/cxCmneaVVAyW9 password: 1e62
Hi guys dumb question but I can't find any info how do you connect the box to PC I have a sumvision x8 which is rockchip 3368 with powerVR G6110, and I would like to root it, but I'm not worried about a custom rom, I also have an mxq and with that I just had to put the twrp recovery image on an external SD there was no need to flash and stock recovery stayed in tact, is that not possible on this ?
Any advise would be very appreciated thanks in advance.
Sent from my HTC One_M8 using Tapatalk
It´s easy...just connect using a usb cable male to male or a male to OTG cable...first install the drivers before...
You can have a look here..
http://ugoos.net/blog/rockchip-firmw...flashing-guide
P.D.:
I hope this helps you..
Originally posted by WAIKIKI728 View PostIt´s easy...just connect using a usb cable male to male or a male to OTG cable...first install the drivers before...
P.D.:
P.s is the little CD rom disk that came in the box the drivers ?
Thanks for your help, I'm new to this box my mxq was so simple to root I just flashed a zip through the updater in settings.
With this method and as much as i know you need a pc to do it...or maybe you can give a trying using this tool Onkeyroot that mo123 has posted for another android tv...
P.D.:
Just one thing ...if you root you will not have OTA UPDATES...if you don´t mind...let´s try...i guess you will loose nothing...
Originally posted by WAIKIKI728 View PostWith this method and as much as i know you need a pc to do it...or maybe you can give a trying using this tool Onkeyroot that mo123 has posted for another android tv...
P.D.:
There are currently 1188 users online. 0 members and 1188 guests.
