check out http://androidtvnews.com/change-xbmc-skins/
Change XBMC Skins and Appearance
Tired of the same old Confluence skin look? If you’re looking to shake things up and change the appearance of your XBMC setup, what better way to do so than to Change your Skin to something different?
check out http://androidtvnews.com/change-xbmc-skins/Last edited by swiftmuvmentz; 29 May 2013, 07:01.Tags: None
There are currently 1830 users online. 0 members and 1830 guests.
