Parameter Help
    Parameter Help
    Hi, not sure if I'll get a response here but basically my 16GB tablet only has 1GB of usable app space & fills up quickly even when moving apps to SD, can someone who knows please post up the values for having 8GB (or 6GB) apps space, thanks.
    Here is my original parameter (1GB app space)
    FIRMWARE_VER:4.1.1
    MACHINE_MODEL:AP-103
    MACHINE_ID:007
    MANUFACTURER:RK30SDK
    MAGIC: 0x5041524B
    ATAG: 0x60000800
    MACHINE: 3066
    CHECK_MASK: 0x80
    KERNEL_IMG: 0x60408000
    #RECOVER_KEY: 1,1,0,20,0
    CMDLINE: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000mtdparts=rk29xxnand:
    0x00002000@0x00002000(misc),
    0x00004000@0x00004000(kernel),
    0x00008000@0x00008000(boot),
    0x00008000@0x00010000(recovery),
    0x000C0000@0x00018000(backup),
    0x00040000@0x000D8000(cache),
    0x00200000@0x00118000(userdata),
    0x00002000@0x00318000(kpanic),
    0x00100000@0x0031A000(system),
    -@0x0043A000(user)
    Re: Parameter Help
    0x00c00000@0x00118000(userdata),
    0x00002000@0x00d18000(kpanic),
    0x00100000@0x00d1A000(system),
    -@0x00e3A000
    This off the top of my head but should get you on your way.
    Sent from my XT890 using Tapatalk 2
    900Supersport
    freaktab developer
      -@0x00e3A000
      Thanks for your quick response, will flash & check it out.
      Edit: Just flashed, all seems well, now got 5.91GB for App Space, should be more than enough, thanks again.
