Somebody please help MBX n200 help with root >>>s812
    Hello everybody I'm looking for some direction here
    My wife purchased a mx 111 or mx 3 what ever you wish to call it from Amazon for me
    And I can't seem to find any real information for it
    I am looking to be able to update it as OTA update finds nothing and I would like to root it so I can remove bloat ware and wotnot IE use adaway
    I downloaded android system checker from play store and it's reporting that its a
    MBX n200 if that means anything to anyone
    Any help is greatly appreciated
    MBX n200
    Sent from my D6603 using Tapatalk
    Also when I watch streams on kodi they keep pausing to buffer and repeating the same thing
    I don't think it's anything to do with my Internet as I have a 200mb connection so that should be ample enpugh
      Can someone please help
      My unit doesn't have recovery on it
      And if I try to update from the app all unit does is switch off and the light on unit flashes red and blue
      It's really starting to get on my nerves and I feel to hit it with a hammer
        Can anybody offer some advice?
        Please
            These are pictures of my box can anybody identify it please
              Lol all I want to do is root this thing Shirley some one can help?
                Have you tried this http://freaktab.com/forum/tv-player-...stock-rom-roms
                  Originally posted by blinkone
                  I did try that on Sunday that's how I came to find that I have no recovery on this and I can't update from the update app that's installed on the box
                    Even if someone could explain how to get recovery onto the box that would be a great help as I would have something to work with
                      Have you tried this http://freaktab.com/forum/tv-player-...mlogic-devices install the one for the N200 PCB
                        No I haven't thank you so much I think that is just what I'm looking for I think I will have to install it using adb as the reset button seems to do nothing as there is no recovery on it
                        Do I have to download anything special to acsess the unit via adb?
                          OK I have managed to get recovery and root on this unit thanks to blinkone now can anybody point me in the right direction to a halfway decent rom? as the one that is on the unit is a pile of pants
                          Thanks in advance
                            Hello gumbo71,
                            you may have one of the hybrid clones, if you do brick it have a look here for help
                            A couple of roms will work on it, none great, based on mbox. Go for openelec if your main interest is kodi
                            In the couple of android roms that work I've had M9 and M8S versions
                            I've seen mbx, n200, k200 & mx3 listed at various places inside them.
                            It actually has S812 and k200 with AP6330 wifi.
                            Only version of TWRP that worked was the K200.
                            All this points to it being a MXiii plus but i've not had that rom working on it.
