Yesterday i received my B13, i will use it for in my car videosystem.
I already have an MK808b, and updated it with finless rom.
Now i'm looking for a custom rom for my B13. I haven't found any yet, but can i use the rom of other RK3066 devices? Which do i need to use then? Or can i adapt one so it fits for my B13.
Hi robbejanvdw, have you found the wifi on this with external antenna better than other devices? If you have not used other devices then is the wifi working ok for you? I have MX1 and wifi is crap, I was thinking of getting a B13 or B11
i have the mk808b and the b13. And the wifi on the b13 is much better than on the mk. When in my room, the mk has 2 or 1 stripes of wifi and the b13 has full range.
So if you want better wifi i sure recommend the b13!
