i have 3 amlogic tv box m8 s802
and have 3 different problem each device
1. i power the device on and its stuck on MBOX logo and dont go to the menu - i try to used usb burning tools and i was stuck with 2% error - and i didnt find sulotion for this problem
2. i have device that when i connect it its not power on but if i looked at the back i see that the optical light flashing in red - the computer not recognize it
3. and one more device that i connect to the electricity and its power on but i got black screen nothing happens - and i try to connect it to the computer its not recognize it
any fix for one of the problem i got crazy with that device i order 3 and after using it for while all of them makes problem
thanks for you support
