Pipo X7 auto power on - Windows only [SOLUTION]
The file has been removed from mediafire by the look of message given Invalid or Deleted File.
The key you provided for file access was invalid. This is usually caused because the file is no longer stored on MediaFire. This occurs when the file is removed by the originating user or MediaFire.Still have questions, or think we've made a mistake? Please contact support for further assistance.
Cheers
Originally posted by AgentData View PostAfter a long time of searching the Internet up and down - flashing and reflashing - and almost killing my SPI programmer
I finally found a solution to let the Pipo X7 auto-boot on power supply without the need to press any button.
The solution is pretty simple:
I found that the Orbsmart AW-05, which is basicly the Windows only version of the Rikomagic MK36, has the wanted auto-boot option enabled.
Download: http://www.mediafire.com/download/ff...o_power_on.zip
Orbsmart site does not have any AW-05 firmware available for download. Also they do not respond to emails.
I still had a copy of the file remember does not work on a duel boot Pipo https://drive.google.com/file/d/0Bzq...ew?usp=sharing
Originally posted by wwmoggy View PostI still had a copy of the file remember does not work on a duel boot Pipo https://drive.google.com/file/d/0Bzq...ew?usp=sharing
Still looking for the X7 version.
Hi, I have a copy for X7 here https://mega.nz/#!IVZSUATI!l3As4EyTA...dCfipg4kvV8BtE
Be careful can brick your device !!! see next postLast edited by stevejc; 23 October 2016, 19:50.
Be careful. Device bricked after running update from this archive, and I had to reflash original bios directly to chip.
Originally posted by stevejc View PostHi, I have a copy for X7 here https://mega.nz/#!IVZSUATI!l3As4EyTA...dCfipg4kvV8BtE
Originally posted by xa1 View PostBe careful. Device bricked after running update from this archive, and I had to reflash original bios directly to chip.
I haven't used it personaly, in post 11 someone had good result
I have updated my post to warn people.
I've installed the new BIOS as per instructions and all went well. Thereafter, Windows 8.1 booted but networking did not work. Reinstalling the Ethernet and WLAN drivers fixed the problem.
For PIPO X7 users, a copy of the BIOS zip file I used is here: http://www.nat32.com/pipo_x7_auto_power_on.zip
I can't enter the BIOS on startup. Tried ESC, DEL, F1 - F8 but none worked. I noticed that the USB keyboard is unresponsive until Windows has started.Last edited by darfnix; 26 December 2016, 01:55. Reason: FIXED. Click your way through PC Settings to UEFI Firmware Settings -> Restart as described here: http://www.howtohaven.com/system/change-bios-settings-windows-8-1.shtml
Thanks so much for this!! and for the folks that provided a new link to get the X7 Bios! I just flashed my pipo x7 with this and all went smooth - just remember to follow the prompts in the command window and wait until the 'congratulations' message. I had no issues at all - makes me now want to get a second PipoX7. I also use the MeeGoPad with a modified bios for autopower on.
There are currently 5667 users online. 2 members and 5665 guests.
